The big 3 , a little confused
so i was looking at my alternator and battery to plan out the big three before hand just to take a look. and the power wire doesnt go directly to the battery. it goes to the engine block i think ( its in a sleeve didnt wanna tear it apart) and then theres a part on the front of the engine block that its connected too then it runs to my battery. the alternator isnt connected directly to the battery, for the big three should i just run it from the alternator to the battery? or just remove the connect that its already got and try to connect the big three how its already wired? im not sure if this is how all cars are i just thought it went from the alternator to the battery. i have a 2001 dodge stratus SE , any help appreciated. thanks much
You don't need to follow the factory wiring route
When you do the upgrade, add onto the existing factory wiring. Don't replace it ;)
ok so i should just run a 0gauge wire straight from the alternator to the battery?
Personally, I would.
Lots of folks here don't fuse their alt to battery. But IMO fuse everything. Would be a shame to have a fire because of a $15 fuse - or lack of
ok, thanks for your help guys , appreciate it
As long as your wire's sheathed in heat-resistant covering, then you shouldn't have your wire ground out. I didn't when I was running two OEM batteries in my '98 Sierra ext, but I only had the 0gauge in there for about 5 months.
It's not that big of a risk, but the danger is extreme.
It's kinda like sex with condoms or sex with birth control & condoms :/
2001 Civic LX Sedan
Pioneer DEH-7500HD
Big 3 in 1/0 Knu CCA
Rockford P500-4
RF Punch P165-S in doors
RF Punch P165 in rear deck
Front doors deadened with Damplifier
Next
SQ's new HDS208 8" in a T-line whenever it FINALLY COMES OUT I CAN FINALLY AFFORD IT
:dammit:
Bend over and I'll show ya.
how is it 2 days work? half a day at most, i may be an idiot, but im not an idiot.
My old volvo was like that, alternator postive went to a starter solenoid then to the battery, I'd just run straight from alt to battery.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
  • Who's Online   0 Members, 0 Anonymous, 487 Guests (See full list)
