The big 3 , a little confused
As long as your wire's sheathed in heat-resistant covering, then you shouldn't have your wire ground out. I didn't when I was running two OEM batteries in my '98 Sierra ext, but I only had the 0gauge in there for about 5 months.
It's not that big of a risk, but the danger is extreme.
It's kinda like sex with condoms or sex with birth control & condoms :/
So heat resistant covering will magically prevent the wire from being chafed through or being pinched in the event of a collision?
Fuse at or a couple amps above your alternator's rating, with the fuse close to the battery
Why not fuse to what the wire is capable of?
im assuming because the alternator cant put out more than what its rated , so there would be no point in putting a fuse much larger i think
Why would you? If you know know the wire is only to be carrying a maximum of 120 amps from a 120 amp alternator, the only thing fusing to 300a would do is delay the amount of time between a short circuit and a blowing fuse. I like to use the smallest fuses possible for an application because of this. Big car audio fuses don't blow immediately like a 5 or 15 amp fuse form your glove box would. They are referred to as "slow blow" fuses and can take some time to actually interrupt the current
  • Who's Online   0 Members, 0 Anonymous, 501 Guests (See full list)
