mrd6 Posted April 14, 2014 Report Posted April 14, 2014 By 25 watts, so 125 RMS total. Im still in the process of looking so I havent comitted yet. That difference will be negligible, go for it! The thing to remember is that more often than not, damage to Mids and highs is mechanical. It's very rare to blow a mid or tweet due to thermal failure. This is why install is so important. Don't cross your tweets to low, and make sure your Mids are installed/crossed correctly and you could probably run double rms to that set without a problem. Since you are running passive you have a bit less control of those parameters (tweeter filter settings) so you may want to be a bit more conservative than that. But as kraken said, you can always turn a larger amp down, but you can't turn a smLler amp up! My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL
14Fusion Posted April 14, 2014 Author Report Posted April 14, 2014 Awesome. Thanks guys, I believe that has answered everything. Luckily for me the higher wattage amp is cheaper. (And as seen from some AD-1 tests is infact true RMS not just lies)
rockFord_Expedition Posted April 14, 2014 Report Posted April 14, 2014 A dd-1 has no idea what speaker is getting hooked up. It just gives you max clean volume/gain. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
baaudio Posted April 14, 2014 Report Posted April 14, 2014 i prefer to be overpowered, because your more likely to get clean power. if you are underpowered you will be pushing gear to try to reach the expectations you have Team NWSPL baaudio Build Log 2001 GMC Sierra walkthrough 4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
