ILikeEggs Posted April 15, 2014 Report Posted April 15, 2014 Okay let's say I'm going to make 6 runs of 0g front battery to back bank.. I would fuse the front runs with a 250amp fuse within 18" of the front battery, then fuse within 18" of the rear battery bank right? Now, would I need to fuse any of the runs between the batteries in the rear? + - + - Between those 2 +s would I add a fuse between each battery like that? Also since I'd run dual alts, should I fuse between their runs to each other? And fuse between the run from the alts to the front battery?
Kyblack76 Posted April 15, 2014 Report Posted April 15, 2014 draw a pic... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted April 15, 2014 Report Posted April 15, 2014 and if you wanna be a popular person, id suggest you keep bumping your shit every 4 mins SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
fecupe2001 Posted April 15, 2014 Report Posted April 15, 2014 i was going to help, but , bumping after 5 minutes?? no way, good luck! I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
ILikeEggs Posted April 15, 2014 Author Report Posted April 15, 2014 draw a pic... Do I have the right idea or is this completely off? The x6 means 6 runs from front to back (not enough room on paper for that kinda clusterfuck) The circles are alts, and the squares between the lines are the fuses. Edit: If you run 6 runs front to back like that, and only running one wire to battery then wouldn't that mean I'm not getting as much power as I could? Like I'm bottlenecking the 6 runs from the front battery then only running 1 wire to each battery?
Kyblack76 Posted April 15, 2014 Report Posted April 15, 2014 and, thanks. i was serious about a pic... thanks..... let us look SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted April 15, 2014 Report Posted April 15, 2014 squares are fuses right? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
ILikeEggs Posted April 15, 2014 Author Report Posted April 15, 2014 Squares on the lines are fuses yes, squares on bottom are batteries.
