I want numbers!
my max dimensions are 27.5" deep, 41" wide, and basically as tall as necessary ...I think around 3 1/2 feet is as high as it will go but probably higher would be fine, since I will only use this at comps I dont mind letting it get high...
The subs and such are in my sig...thanks to anyone who helps
A vitrolic, megalomaniacal sadistic psychopath.
so, your going slide out wall?
And since your saying PURE spl, your looking for about 60-70hz?
Is it in the jeep are you keeping it in the cargo area? Or can you go to the b pilar?
Also you need to know your res. Freq. Of the car and tune your box you that freq.
Edited by Team Bassick (ALPINE)
basically I just want a box in the cargo area (have to keep the seats) the gets as loud as possible... It has to be removable because for daily bumping I want the box I have now... I don't know how to find res. frequency????
Build it as big as you can subs up port back it should be a big. Port then tune it to res of the car if its the jeep
To find freq. there are a bunch of ways you can do that you will need a meter to do it there should be a thread here some where to tell you how to do it
If not here check out www.dbdrag.com in there audio fourm I know they show a bunch of ways to get freq.
In my experience with my Bl 18s I got louder with a smaller box. 10ft w/ 4 6" ports tuned to 32hz (so it still played deep) powered by a pair of T1ks hit a 148.3 @ 41hz (my res freq) in my Yukon. No doubt higher tuning and a higher res will be louder. Sorry but I never went all out spl. If I was to start testing again I would start with the same box though.
Edited by Derrick824
  • Who's Online   0 Members, 0 Anonymous, 2309 Guests (See full list)
