Aj11 Posted April 16, 2014 Report Posted April 16, 2014 hey guys I'm pretty sure this is what I'm gonna run for my 15. (After much debating) and Just want to see if any of you have used one. if so what tune did you use and how did you like it? thanks again for any input jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
whatusay45 Posted April 17, 2014 Report Posted April 17, 2014 I've never seen that kind of design? Looks cool
Krakin Posted April 17, 2014 Report Posted April 17, 2014 Just with any other enclosure that needs to be tuned to a frequency, a dual chamber reflex will not need to be designed around other people's choice in tuning, but for the driver in use and the application it is use for. Here is a nice write-up on designing one. http://www.diysubwoofers.org/prt/dual_chamber.htm Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener.
Aj11 Posted April 17, 2014 Author Report Posted April 17, 2014 i was seeing if others used one and.what tune they used. i know you can't really tune the second chambers port. it usually is higher then the first. that's because all Ports will be the same length and the chamber the sub is in is bigger then the other. for instance say the sub chamber is 3.5 and the other 2.5. if they both had a 6inch port 18inches long the sub chamber would be tuned to 30hz while the smaller 39hz. the port connecting them would.also be 18inches long. i know a Lil about them just seeing if anyone has used one. i will be using a slot vent not ports tho like this, still trying to figure out a Size thinking about 6ft gross maybe a Lil bigger because of sub displacement and the room all the ports will take up. from what i understand it acts allot like a sixth order but much smoother. jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
Tecomah Posted April 17, 2014 Report Posted April 17, 2014 Interested to see how this turns out 750??! Yeah, fuck that. Fuck this website, fuck SMD, fuck Steve, fuck all of his butt buddy mods, and their couches.^ DON'T BE A DICK LIKE THIS GUY Team Subsonic Lows
Aj11 Posted April 17, 2014 Author Report Posted April 17, 2014 thanks me to! i wanted something that not allot of others had. i think i found it! the sub I'm getting wont be in until the middle of May so the box wont be up and running for a Lil bit. that's why I'm doing so much research now. when everything gets here I'll do a build log and post vids to show. anyone else use/hear one? jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
CleanSierra Posted April 17, 2014 Report Posted April 17, 2014 That's a LOT of wave manipulation. Im not the one you want to try to troll. Just a fyi for you.
TheCamBeck Posted April 17, 2014 Report Posted April 17, 2014 i have heard these boxes being called an ABC box before if I'm correct.
CleanSierra Posted April 17, 2014 Report Posted April 17, 2014 Abc is an Aperiodic box with a penetrable membrane usually^^^ Im not the one you want to try to troll. Just a fyi for you.
Aj11 Posted April 17, 2014 Author Report Posted April 17, 2014 they help control excursion levels at two different points. at some frequencies the sub doesn't "see" the other chamber it just acts like one big box jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
