john253a Posted April 18, 2014 Report Posted April 18, 2014 yes it will but you, but not all amps can be set with a 0db track with the dd1 i know my zx750.1 when i set gain, you use the 0db to find h/u then i turned amp up and only got 1 click from 0 (0-11) so to 1 on gain was 0db, i then checked amp with -5 and -10, and i got 5/11 and 6/11, but because i was doing a sq build i set it @ 4/11 because i was chasing a -3db with a bc3500 idd find what 0 and -5db tracks are and put it between the two if your running 1ohm final what coil config do you have, another option if you have d4 coil is t-line them at 4ohm final
barney91 Posted April 18, 2014 Author Report Posted April 18, 2014 yes it will but you, but not all amps can be set with a 0db track with the dd1 i know my zx750.1 when i set gain, you use the 0db to find h/u then i turned amp up and only got 1 click from 0 (0-11) so to 1 on gain was 0db, i then checked amp with -5 and -10, and i got 5/11 and 6/11, but because i was doing a sq build i set it @ 4/11 because i was chasing a -3db with a bc3500 idd find what 0 and -5db tracks are and put it between the two if your running 1ohm final what coil config do you have, another option if you have d4 coil is t-line them at 4ohm final i do have the d4, i still have the t-line i had them before but its been sitting in my moms garage for a while and it picked up moisture, plus i want to try a normal ported box or a 4th order Alpine 9884 RF T2 comp set up front The Epicenter 2x RF T10001bd 2x Sundown sa-15 t-line Big 3 Smd DD-1
barney91 Posted April 18, 2014 Author Report Posted April 18, 2014 How's this sound 32L x 40w x 14.25h, the port will be 24L x 8w x 12h Alpine 9884 RF T2 comp set up front The Epicenter 2x RF T10001bd 2x Sundown sa-15 t-line Big 3 Smd DD-1
FUKAZ28 Posted April 18, 2014 Report Posted April 18, 2014 Ever thought of selling the subs and getting some that can take the power?
CleanSierra Posted April 18, 2014 Report Posted April 18, 2014 Are you going to run the subs at 4 ohms final load or 1 ohm final load at the amp? Im not the one you want to try to troll. Just a fyi for you.
john253a Posted April 18, 2014 Report Posted April 18, 2014 ported 4ohm final just won't do them justice, but will work, if you ask me there are a few options sell them and get something that will take the 3500 like a pair X or maybe a hdc3, lvl4 sell them and buy a single 18 that will take the 3500 like a z, hdc4, lvl5 but another 2 and iso them or even iso 4th run it a 4ohm ported 4ohm iso t-line buy 1 more and run sealed @2.66 ohm
CleanSierra Posted April 18, 2014 Report Posted April 18, 2014 He said tight budget though in his first post, so that's why I was inquiring John. I wouldn't even design a box knowing for those, knowing that triple the RMS would be sent to those 2 subs with 2.5" coils. The option that John mentioned that I do like is selling the 2 subs for a single 18" sub of a higher series, like Sundown X and run at 2 ohms final. Used maybe? Or a couple of used HDC3 15s? Im not the one you want to try to troll. Just a fyi for you.
barney91 Posted April 18, 2014 Author Report Posted April 18, 2014 Yes i have thought about it but not many people know what they are, and final load would be 1ohm . would the specs i posted up work for a pair of Xs Alpine 9884 RF T2 comp set up front The Epicenter 2x RF T10001bd 2x Sundown sa-15 t-line Big 3 Smd DD-1
CleanSierra Posted April 18, 2014 Report Posted April 18, 2014 Is that design with a center pretty, firing back at the hatch? Im not the one you want to try to troll. Just a fyi for you.
barney91 Posted April 18, 2014 Author Report Posted April 18, 2014 He said tight budget though in his first post, so that's why I was inquiring John. I wouldn't even design a box knowing for those, knowing that triple the RMS would be sent to those 2 subs with 2.5" coils. The option that John mentioned that I do like is selling the 2 subs for a single 18" sub of a higher series, like Sundown X and run at 2 ohms final. Used maybe? Or a couple of used HDC3 15s? my wife didn't say a number but i know 300 or 400 tops it, but I'd rather get a bigger battery and better amp to run my front stage Alpine 9884 RF T2 comp set up front The Epicenter 2x RF T10001bd 2x Sundown sa-15 t-line Big 3 Smd DD-1
