TITUS1985 Posted April 20, 2014 Report Posted April 20, 2014 This is probably a really easy answer but I can't seem to find one. All I'm wondering is can you run a 4 channel amp at different loads? Like running the A channel at a 2 ohm load and the B channel at a 4 ohm load. Can you do this or will the amp not work right because all the channels aren't at the same ohm load? My amp I have is the Hertz HDP 4. Thanks in advance
hdorre Posted April 20, 2014 Report Posted April 20, 2014 on most amps, you're good. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
Smoove Posted April 20, 2014 Report Posted April 20, 2014 I did it on a 4 channel RF for years. ran the front channels at 4ohm to the doors and the rear channels were bridged to the sub. Make sure you properly gain set and should be fine. 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
TITUS1985 Posted April 22, 2014 Author Report Posted April 22, 2014 Ok like you guys said my amp should be fine, but I was looking at the RMS watts for each configuration and this is what it says 4 channel 150x4 @ 4 ohm 4 channel 250x4 @ 2 ohm 3 channel 150x2 + 500x1 @ 4 ohm 3 channel 250x2 @ 2 ohm + 500x1 @ 4 ohm 2 channel 500x2 @ 4 ohm None of these configuration are what I was thinking. I was thinking of running 4 channel 250x2 @ 2 ohm + 150x2 @ 4 ohm Since this option is not on the list should I just stay away from it? Thanks again.
