Mechman Alternators
Running without the regulator
I started my truck with command start this morning, and I wondered if the regulator in the secondary alternator was actually on. Obviously, using command start means the key isn't in the ON position, and I did check with a DMM...and sure enough the 12v ignition that I tapped into doesn't turn on with the command start but does as soon as I put the key in and turn it to the ON position.
Bad for the alternator to run without the regulator turned on? It didn't run for more than a few minuets, but should I switch to a different source?
Edit: The secondary just has the single 12v turn on wire.
Edited by TRON
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
Tuned in for results, I will be going though this exact same scenario shortly....
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Shouldn't matter but it's bad for reg to be on and alternator not turning I have triple alts an use to swap to one for a class in meca I was to to unplug the regulator or I could burn it up
Edited by AA98hoe
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
So I'm guessing that without the regulator turned on, the alternator still will generate some kind of electricity but not enought to do any damage?
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
  • Who's Online   0 Members, 1 Anonymous, 927 Guests (See full list)
