help with box design for rockford p3 12
Scalian
Should I slide my sub to the left so that the whole sub fires into the port wall instead of part of it firing into the opening?
Got the box built and installed. Happy to report my rear view mirror is no longer useful. Thanks everyone for the help. Still hard to believe how much diffrence a box made.
Box design is everything when it comes to getting loud or sounding good.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Paint or carpet it
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Still need to carpet the box. Have some black carpet to match the trunk. I was happy to be able to add some bass to the system and not use up the whole trunk. Nothing to exciting about the box just put it together like the drawing. There is a little step down in the truck so i need to get some little feet or something for the corners for the back that are facing back to the trunk lid. Carpet will be the next quick project just wanted to hook up everything and make sure I got the sound i wanted before carpeting the box. I did end up using hurricane nuts and machine screws to mount in the sub. I also used bolts with a washer and lock nut to put in the terminal cup. Once the box is carpeted i just need to clean up the speaker wire runs for the rear deck and then the sub wires and it should be done. i also ordered the Rockford grill that fits under the trim ring to keep the sub protected.
would u guys b willing to help me design a box for the same subs,a pair of dual 4 ohm 12" rockford p3 subs with a 1500 watt rms load ? i have a blazer with 36"w x 20"h x 24"d space available or i can go mini wall with 36"w x 30"h x 15"d
I would start a new thread asking for a box design. I think you are going to want to be around 3.6 ft^3 net. I did half that for one speaker.
i did start one and i got 1 reply to is that says:
3.6net 65sq" of port 42hz
Or 2x 6" aeros
i do have a post tho, and i would be greatful for help, im sorry i did not mean to intrude on this.. jus was same sub i have...
  • Who's Online   0 Members, 0 Anonymous, 3018 Guests (See full list)
