head unit/eq
Yes but if you still send a garbage signal to the EQ you are going to get 7 volts of amplified garbage.
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
The higher the voltage the lower your gain needs to be set on your amps. If you pre-out voltage is too low you might not reach the full power from your amp before the gain hits the clipping point.
Flame me if I'm wrong I am here to learn as well.
2010 Mazda 3s 2.5L
Knu OFC 1/0
You might not be able to get all 7 volts out of that equalizer. It depends on how much voltage gain your amps have. For example i have a fosgate 4 channel amp and a hifonics mono amp. The hifonics gains go from 6v to 0.2v and the fosgate only goes from 4v to 0.2v. Therefore i can only set the volume on the eq to match the 4 volts from the fosgate amp and also for the mono amp due to the limitation of the 4v max on the fosgate amp. Im guess your buying the Clarion eqs746? If you dont set it up right you will risk overdriving your amps.
With an Eq / line driver you need to be very weary. when you do this you introduce more factors , that can have an adverse affect. I.E. more places for EMI to get in or turning a clean signal into a dirty amplified signal. yes more volts = louder but if its not clean its not worth it.
No 1 But me paid for this stuff and NO FREEBIES so no brand names (No Free Advertisement )
A SQ head unit
6 5.25
2 X 6x9s
7804
P400.4
4001D
1 34s (Maybe time to change brand)
4 X 15" s
!/0 @ 2/0 OFC Wiring
:morepower1: :morepower1: :morepower1: :morepower1:
ill say it like i always say it. F##K the DD-1. I don't care if you or anyone buys one. (well i do, but that isn't my point) Get an O-scope in the very minimum and learn how to use it or you are just guessing your settings like every other noob. :) once you master the O-scope then step up to a DD-1 or even better a DD-1 Plus.
  • Who's Online   1 Member, 0 Anonymous, 315 Guests (See full list)
