oldsoundguy Posted April 25, 2014 Report Share Posted April 25, 2014 That's a fucking rats nest of speaker wire going into that amp. Cant make heads or tails of it. I will say that if you have more than one speaker wire in each of the pos and neg terminals then you have changed the ohm load of that set of speakers. How did you get 1/0 power wire in a 4 gauge power and ground in the amp? 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/ Link to comment Share on other sites More sharing options...
matt.b Posted April 25, 2014 Report Share Posted April 25, 2014 That's a fucking rats nest of speaker wire going into that amp. Cant make heads or tails of it. I will say that if you have more than one speaker wire in each of the pos and neg terminals then you have changed the ohm load of that set of speakers. How did you get 1/0 power wire in a 4 gauge power and ground in the amp? it looked stuffed I thought it could be arching Link to comment Share on other sites More sharing options...
Blake Farrar Posted April 25, 2014 Author Report Share Posted April 25, 2014 Making sure bass is shooting out both sides in case you're in the middle lane is a sure fire way to add DB's and shut the streets down you talk shit but i bet if you heard it you would think different. Link to comment Share on other sites More sharing options...
Blake Farrar Posted April 25, 2014 Author Report Share Posted April 25, 2014 That's a fucking rats nest of speaker wire going into that amp. Cant make heads or tails of it. I will say that if you have more than one speaker wire in each of the pos and neg terminals then you have changed the ohm load of that set of speakers. How did you get 1/0 power wire in a 4 gauge power and ground in the amp? it looked stuffed I thought it could be arching there not even close but i can see how you would think that Link to comment Share on other sites More sharing options...
Ahmed Johnson Posted April 25, 2014 Report Share Posted April 25, 2014 Man, I just checked your bro out on you tube and he seems to know a little something. Why don't you ask him to walk through your system with you? Link to comment Share on other sites More sharing options...
oldsoundguy Posted April 25, 2014 Report Share Posted April 25, 2014 Oldsoundguy OUTAA 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/ Link to comment Share on other sites More sharing options...
alaskanzx5 Posted April 25, 2014 Report Share Posted April 25, 2014 I think I see stray wires sticking out. and I'm I the only one that saw something saying he is running 1 of the channels at 1ohm? Don't think that amp is 1ohm stable... t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
Blake Farrar Posted April 25, 2014 Author Report Share Posted April 25, 2014 That's a fucking rats nest of speaker wire going into that amp. Cant make heads or tails of it. I will say that if you have more than one speaker wire in each of the pos and neg terminals then you have changed the ohm load of that set of speakers. How did you get 1/0 power wire in a 4 gauge power and ground in the amp? like i said ive been working on it and its 2 cross overs per channel so 2 + and 2 - and how else do you think i got 1/0 guage into 4 guage termianls a little trimming Link to comment Share on other sites More sharing options...
alaskanzx5 Posted April 25, 2014 Report Share Posted April 25, 2014 Making sure bass is shooting out both sides in case you're in the middle lane is a sure fire way to add DB's and shut the streets down you talk shit but i bet if you heard it you would think different. based o. The static we would hear.im sure we would think different of you installing. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
Ahmed Johnson Posted April 25, 2014 Report Share Posted April 25, 2014 Making sure bass is shooting out both sides in case you're in the middle lane is a sure fire way to add DB's and shut the streets down you talk shit but i bet if you heard it you would think different. I don't think so. Actually yeah I might. Right now I find it hilarious but if I actually heard I might get mad. Link to comment Share on other sites More sharing options...
