low voltage causing rpms to drop?
Assuming the car otherwise runs fine, low/stuming idle is typically
A. IAC/idle air control valve inop or dirty as Hell.
B. Throttle body dirty as Hell
C. EGR malfunction stuck open at idle.
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
I have to keep Idel up When parked. Or I drop mid 12s and my rpm starts to move around. I just hold it a bit over 1000-1500 rpm. You should just do the same. Also not play at stop lights.
Like if I'm at a light. And play full tilt I drop voltage down to 12s then It will stay there until I push on the gas. Because I don't think the salt is charging at the 500-600 Rpm idel
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
  • Who's Online   0 Members, 0 Anonymous, 487 Guests (See full list)
