Stock HU, Line Out Converter, Dummy Load
If you need to make it think it sees a load determine what ohm load you need and get a resistor 3-5 times greater in wattage rating so that it wont overheat on prolonged play.
The resistor will load down the radio but will transform the wattage to heat.
you can get a pair of resistors for around $8
Okay now repeat that but in Engrish please lol. I need it to see a 4 ohm load I would assume. What size resistor would you say?
How much power is that HU putting out? Or is it an amplified factory system?
I would get two of these:
http://www.amazon.com/Amico-Chassis-Aluminum-Wirewound-Resistor/dp/B008IE2F44/ref=sr_1_1?ie=UTF8&qid=1398994662&sr=8-1&keywords=100+watt+resistor
and use them in place of the speaker. If your factory system is pushing more than than 100 watts i would get four 8ohm versions and wire two down to 4 ohms to have 200 watts of power. The resistors are not polarity sensitive so it doesnt matter what side is + or -
other than that just make sure they are tucked in a spot where teh heat wont effect anything
Rolex you sicken me.
Just let me finish my pie
~ Juice
So, speaker negative to one side, speaker positive to the other, doesn't matter which end?
Correct
On any resistor it doesn't matter. Technically the resistor creates a dead short and dumps the energy as heat.
~ Juice
Correct
Can you still grab that signal from the speaker wire for the LOC? Before the resistor?
SMD Super Seller
My Feedback Thread
Correct
yes you could
but remember that the the resistor is one load (ohm) and the LOC will be putting another load on the circuit. those two combined will present a different load to the source since you now have created a paralleled circuit. I don't think it will be an issue and I'm not even sure what type of load an LOC presents.
~ Juice
No more that maybe 15w per channel and I doubt even that.
2013 Dodge Charger
Build Log
1996 Ford Explorer XLT 5.0
Build Log
2005 Honda Civic LX Coupe
Build Log
SMD SUPER SELLER!!!!
My Selling Feedback
My plan was to get 6 of these run wire into them and then pull 6 channels out of it for the LC6i. The stock HU can't be producing that much power so I was going to mount these under the rear deck now I should be able to pull the signal properly and run new wires to my speakers like I want, correct?
2013 Dodge Charger
Build Log
Build Log
Build Log
My Selling Feedback
  • Who's Online   1 Member, 0 Anonymous, 1446 Guests (See full list)
