How much power can a stock elec run?
My dad wants to have a small system put in. He just wants to have subs installed so I'm thinking about 2 10's or 1 12". He has a 2006 Honda Oddessy Touring edition van. How much power can I run on a stock car? Was thinking running 2 10" Kicker CVR or 2 10" Alpine Type R maybe off a 800watt amp.
Car: 2012 Acura TL Elite
Head Unit: JL Audio Fix86
Front Stage : Alpine SPX-17PRO
Rear Stage : Alpine SPR-60C
Component Amp : JL Audio HD 600/4
Sub : 1 12" JL Audio W7
Sub Amp : JL Audio HD 1200
800 sounds good for a stock.. upgrade the wires with big3 (not expensive and will help for sure)
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
Man I have a 2012 Ford Focus 150a alternator, no big 3, no agm batteries or anything. Got a CT Sounds 1400.1 on 4 gauge Execution Audio CCA wire, and voltage doesn't drop below 13.5 full tilt while driving.
honda alts are like half the size of the focus alts.
depends on stock alt focus, some alts are only 70 amps, with electronic load detection which sucks
yessir. Right. Can't wait until I get my 0 gauge wire installed and my NSB 34AGM
should hold me at 14 HOPEFULLY
as for the OP, 800 watts shouldn't do too bad on stock electrical. Do the Big 3 and your pops should be set
yeah I just realized that lol
I think I will run a single 12" Type R off a 550 Alpine Amp at 2ohms or a Rockford fosgate at 750 at 1ohm. Which amp would you suggest would work best off stock electrical? I wont be powering the Type R to its full potential but it should still hit pretty hard? Should this sub+amp combo be fine on everything stock electrical? Ill put the link below.
http://www.sonicelectronix.com/item_45521_Alpine-SWR-12D4.html
http://www.sonicelectronix.com/item_45519_Alpine-MRX-M55.html
http://www.sonicelectronix.com/item_34763_Rockford-Fosgate-R750-1D.html
How much do you want to spend total
Do you plane on a sealed box or ported
How much trunk do you plane on giving up
In my area most dads want a system and want a trunk
So I normal go for a single sealed 10 or 12 depending on depth under rear shelf
And nice 4+1 or 5ch amp
Some half decent comps from and rear
All up under 1k total installed
5ch amp
http://www.sonicelectronix.com/item_67770_Rockford-Fosgate-P1000X5.html
Sub and box
http://www.sonicelectronix.com/item_34748_Rockford-Fosgate-P3-1X12.html
Mids/highs
http://www.sonicelectronix.com/item_61207_Rockford-Fosgate-P165-S.html
$900 for everything except wiring
  • Who's Online   0 Members, 0 Anonymous, 464 Guests (See full list)
