Need help with an sq system
So if I go with some 5 1/4s then I should be able to get the adapters from sonic electronics?
2012 Chevrolet Cruze
Anybody reading this know the wattage of the factory 8, could probably do with some upgrading.
Dbl Post.
Wouldn't he need a line output converter since he is keeping his stock headunit?
Actually, from the reading I did on the ford truck forums, he would need a signal processor... which isn't cheap
You guys seem to be doing a fine job with out my help ...
You will not be able to use a different headunit, So a processor will be required for this particular vehicle (if I remember correctly)
The stock sub enclosure could be feefed up by adding polyfill, deadner, upgrading the wire and driver ...
  • Who's Online   0 Members, 0 Anonymous, 499 Guests (See full list)
