chasing DB 150+ @kick *Singer/XS Power/3 15"/6Kw*
0c217bc7-52bf-4003-807a-784ee4ebe148_zps
amp rack, line driver, & d3100's
20130505_151344_resized_11_zps028c6dfd.j
wall set-up. currently has 5/8" threaded rods inside the box around all port corners.
while "wall" was being built
20130310_155816_resized_11_zpsc575480f.j
box has around a gallon of resin inside as well.
thought i recognized you from the mattoon show.. i was in the clunker white quiet s-10
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
This box did 151.7 in dB Drag. I put it together the night before the show and the day of the show I used a piece of PVC pipe and some gorilla tape to lengthen the port to tune properly.
By comparison, this is one that I tried with 3 12's firing forward:
This alignment did low 148. I tested rotating the box 90 degrees and it gained about a db and a half firing to the side.
If you attempt to seal off the box LMK what you manage to gain. I really want to try to c-pillar wall, but I fear that apart from being able to show off the amp I'll gain little or nothing.
