mchampa Posted May 2, 2014 Report Posted May 2, 2014 I'm looking to add an XS battery to a new build. Will be using Rockford P500X1 & P400X2 amps. Which XS battery would be recommended for power? Also, 12 V or 14 V battery?
Ahmed Johnson Posted May 2, 2014 Report Posted May 2, 2014 Do you already have a battery under the hood? I'm not sure how how much you know about car electrical so I would tell you go 12v. to be safe
youngbass98 Posted May 2, 2014 Report Posted May 2, 2014 You would be just fine with a xs d3400 12v 06 monte carlo 2 12 rockford p3s soundstream rubicon 2500 crescendo audio mezzo 6.5 ct sounds 125.4 execution audio and shca wiring 2 xs d3400 on stock alt
afrakes Posted May 2, 2014 Report Posted May 2, 2014 12 volt. Unless you have a ho alt and an external regulator to run at 14 or 16 volts. Vehicle: 2014 GMC Sierra 2500HD WT Head Unit: Pioneer DEH- Mids/Highs: Focal Integration ISC 165’s (front) Subs/Amps: TBD
Rmichael91 Posted May 2, 2014 Report Posted May 2, 2014 Whats the vehicle? Stay 12v. With the space, a d3400 would do you fine. Solved my issues so far until I start my substage.
FocusOn20s Posted May 2, 2014 Report Posted May 2, 2014 what size alt do you have? may not even need batteries I have a CT Sounds 1400.1 on bone stock electrical, not dropping below 13.5 full tilt according to my bass knob. Voltage according to the EVIC is 13.8
BLuejoules Posted May 2, 2014 Report Posted May 2, 2014 3400 under the hood should be good IG: devinthydude
Aj11 Posted May 4, 2014 Report Posted May 4, 2014 what size alt do you have? may not even need batteries I have a CT Sounds 1400.1 on bone stock electrical, not dropping below 13.5 full tilt according to my bass knob. Voltage according to the EVIC is 13.8 how did you set your gain? i have the same amp and I'm dropping more then that. not to mention civics have notoriously small amp alts mines a 120alt and full tilt i go low! if i don't clip on the knob it stays in the 13.4/13.8 area but full Tilt on a dd1 i get into the 12s jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
FocusOn20s Posted May 4, 2014 Report Posted May 4, 2014 what size alt do you have? may not even need batteries I have a CT Sounds 1400.1 on bone stock electrical, not dropping below 13.5 full tilt according to my bass knob. Voltage according to the EVIC is 13.8 how did you set your gain? i have the same amp and I'm dropping more then that. not to mention civics have notoriously small amp alts mines a 120alt and full tilt i go low! if i don't clip on the knob it stays in the 13.4/13.8 area but full Tilt on a dd1 i get into the 12s set my gain using the clipping light on the knob and a -2.5db test track 150a alt stock and 4 gauge EA wire lol. I shit you not. I also only play my system mainly while driving. I still want to get an AGM underhood, and my 0 gauge wire installed. Hopefully, that'll keep me in the 14s
jarrius Posted May 4, 2014 Report Posted May 4, 2014 Just upgrade your battery under the hood to a xs power and you should be fine 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
