You would be just fine with a xs d3400 12v
06 monte carlo
2 12 rockford p3s
soundstream rubicon 2500
crescendo audio mezzo 6.5
ct sounds 125.4
execution audio and shca wiring
2 xs d3400 on stock alt
12 volt. Unless you have a ho alt and an external regulator to run at 14 or 16 volts.
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
what size alt do you have? may not even need batteries
I have a CT Sounds 1400.1 on bone stock electrical, not dropping below 13.5 full tilt according to my bass knob.
Voltage according to the EVIC is 13.8
how did you set your gain? i have the same amp and I'm dropping more then that. not to mention civics have notoriously small amp alts mines a 120alt and full tilt i go low! if i don't clip on the knob it stays in the 13.4/13.8 area but full Tilt on a dd1 i get into the 12s
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
set my gain using the clipping light on the knob and a -2.5db test track
150a alt stock and 4 gauge EA wire lol.
I shit you not. I also only play my system mainly while driving. I still want to get an AGM underhood, and my 0 gauge wire installed. Hopefully, that'll keep me in the 14s
Just upgrade your battery under the hood to a xs power and you should be fine
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
