Have 2 subs but they move opposite of eachother
if you were close to me and if i new My box would fit in you car(what car is it?) id sell you my box cheap! it's about 6ft gross tuned to 30hz i built it
1994 Mercury Grand Marquis GS
I have 2 subs
Max Enclosure Size (W/H/D): 44/27/27
Model SXX v2 15
Mounting Depth[in/mm] 8.5 / 215.9
Overall Diameter[in/mm] 15.5 / 393.7
Displacement[cu.ft/liters] 0.17 / 4.81
Weight[lbs/kg] 27.9 / 12.66
Subs - Dual RE Audio SXX v2 15D4 wired at 1 ohm
Door Speakers - RE REX 5x7/6x9
Battery - Kinetik HC 2000
Sub Amp - Crescendo BC2000
Door Amp - Alpine MRP-F300
Head Unit - Pioneer DEH-X8600BS
oh there 15s this box is for 12s
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
yeaaa my dad always had 15s while i was growing up so i just cant find it in me to go any smaller than 15
http://www.jamcamera.com/vid.php?id=LAYf this is all i could get, its delayed audio for me, doesnt look like its doing justice tho, the left should be slightly off
vid won't play for me, but you could prolly cut the wholes big enough but the box would be on the small side for 2 15s.
I'm upgrading from 2 decent 12s to one bad ass 15
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
if i cut the holes bigger itd probably screw the tuning like crazy, what 15 are you gonna get?
No, it wouldn't screw the tuning. First of all, good luck cutting the existing holes larger, unless you're a whiz with a jigsaw.
A router could do it but would require some trickery. The tuning would likely just raise slightly, due to a little more displacement from the 15" sub vs. the 12" sub. An increase in tuning would be a beneficial thing for you.
I build boxes and wouldn't be a fab of modifying an existing box for 12s to fit 15s. I like being able to use a router to cut circles. Since you have no center point to mount the router(which in sure you don't have anyway, since you mentioned you do not have tools), that's not an option. A jigsaw would be your tool to use, and as I said, it would be difficult to get a hole cut correctly that wasn't all kinds of fucked up.
They look to be moving the same to me. Oh and I didn't just get done smoking LOL
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
  • Who's Online   1 Member, 0 Anonymous, 1482 Guests (See full list)
