Chrisxfl15 Posted May 3, 2014 Report Posted May 3, 2014 So I have a c2 threatcon powered by a audio pipe apsm 1500. I am running 4ga from the main battery back, but I'm dropping voltage like crazy, I would like to hear what you all recommend for a batter to pair with my amp?
youngbass98 Posted May 3, 2014 Report Posted May 3, 2014 Just get a big agm battery for under your hood 06 monte carlo 2 12 rockford p3s soundstream rubicon 2500 crescendo audio mezzo 6.5 ct sounds 125.4 execution audio and shca wiring 2 xs d3400 on stock alt
hazestorm23 Posted May 3, 2014 Report Posted May 3, 2014 You shouldn't need much. At least look at the under the hood xs power batteries
Jlan Thr Smth Posted May 3, 2014 Report Posted May 3, 2014 The diehard Platinum batteries from Sears are great and you can pick them up for not a bad price. They are actually oem'd by Odyssey.
Rmichael91 Posted May 3, 2014 Report Posted May 3, 2014 Power (R.M.S): 500W @ 4 Ohm 1000W @ 2 Ohm 1500W @ 1 Ohm How are you wired down? What's your starting battery? Did you properly tune your amp?
Aj11 Posted May 3, 2014 Report Posted May 3, 2014 you really should upgrade your 4g to 0g not to mention did you do your big 3? running 4g from bat to bat is really small. if anything run 0g from bat to bat then 4g to amp. still 0g is better. jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
Chrisxfl15 Posted May 3, 2014 Author Report Posted May 3, 2014 No I did not do the big three, amp is wired to 1 ohm, just using one battery right now, alt is only doing 85 amps
Rmichael91 Posted May 3, 2014 Report Posted May 3, 2014 I think it might be time to do the big 3, look into an alt and battery (assuming your already planning on going bigger), and maybe adding another battery.
Chrisxfl15 Posted May 3, 2014 Author Report Posted May 3, 2014 Can't I put a kinetic in to stop the power loss or at least help it?
Rmichael91 Posted May 3, 2014 Report Posted May 3, 2014 Dont mix a wet cell lead acid battery with an agm battery. You could add it and should be alright. Still suggest the big 3 though.
