This is going to be my first big build most ive ever ran in the past would be 1 15 in a 1.5 cube ported
box tuned to? With a 1200w rms amp at 1ohm.
I had stock electrical with big 3 done in 8 gauge and a brand new battery under the hood and 70 amp alt.
Ive been told I should make a build thread so here is is. Ill post pictures in a few days
The build wont start till I have every thing I need.wanna get it all done at the same time
then change stuff from there.so I dont have to keep taking stuff apart like usual lol
I would also like to thank oldsoundguy for giving me a good deal on the 2 amps lol
head unit-alpine 9884
speaker amp-ct sounds 125.4 white version
sub amp-ct sounds 3000.1 black version
Wire-1 22ft run of 4gauge,15ft of 1awg,10ft of 1awg all welding cable
thats all I have sofar lol
oh I have 1 sound qubed hds200 12 in a ported box
made by me and my gf desighned by joe x 2.5 cubes to 34hz
powered by a fosgate p6002 600w rms lol it slams tho
Your welcome for the deal. Glad I could help out a young bass head. We need pics as soon as the amps show up.
You have a good start to a nice system.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
Keep in mind im 19
2000 honda civic
yea I just changed the big 3 grounds to 4 gauge, the 8 gauge from alt to battery will work
for now im only running 600w rms right now.
ill go 1awg for the big 3 and system once I get the car apart and everything ran,
Gonna run 2 agm batterys in the trunk
Still debatin on 4 soundqubed hds300 10s or 2 hdc312s
Either setup would be about the same amount of cash
beniefit I see of 4 10s is more cone area, but I cant rebuild it because they dont sell rebuilds
but 2 12s hdc3 can get rebuilt but they have less cone area
You'll need to do this eventually - http://www.stevemeadedesigns.com/board/topic/139844-how-to-eld-bypass-for-honda-civicaccordfit/ It's the ELD bypass for your charging system.
Hmmm if your looking to spend the money, you can fit an XS Power D5100® I think, in the stock location. 2 Smaller battery's like S975s or XP950s should hold you over just fine for what you have listed so far.
Yea the 5100r
r stands for reverse battery terminals I guess lol
Later ill get a dc 180amp alt if the stock one cant keep up
with the 3 batterys
my voltage is always higher than 13.5v even with system full tilt, ac full blast and headlights at idle
Keep in mind im 19
2000 honda civic
If I did 4 10s I would do sub up port back
2 12s would be facing inside the cabin when the seat is folded down
You can find a recone for almost any sub. PSI does plenty.
4 subs you'd have to be really precise on the math so they all load/unload properly.
2 12's into the cabin sealed off from the trunk would run pretty well. Isn't there a ski hole in the backseat for like an arm rest?
If you've got the extra 4ga, swap out the power run so you don't get bottlenecked.
