Computer question for my fellow nerds.
I have a customer of mine who wanted me to backup their info from their laptop. I removed the HDD and went to image it over to another hdd that I have at the shop, and it fails. I wanted to put it on a different machine and just read their info off of it, but it won't read it from my windows 7 machine. The HDD on the laptop has win 8 on it. Is there anything I can do? They have their quickbooks on there and I would like to be able to save the day. Thanks.
2004 Pontiac Vibe Build
Sony MEX-N5000BT
JBL P660C x 2
Sundown Audio Zv4 18
Crescendo BC2000D
Crescendo S800/4
Execution Audio 0 AWG Wire
Sky High Car Audio RCA's
Toolmaker Terminals
XS Power D1200
DC Power 240HP Alternator
Viper 5706
How much is there to move. Usb drive would work but it'd be slow as fuck.
That's the problem. When the drive is in the laptop, it doesn't boot all the way up. It is a 1TB drive too. :(
I downloaded clonezilla utility trying to just image it over to another 1tb drive and then go from there... but it won't image over. I keep getting the same error message that it is either waiting for a check, or that it didn't shut down cleanly. Both of which I have tried to remedy to no luck.
Sony MEX-N5000BT
JBL P660C x 2
Crescendo BC2000D
Crescendo S800/4
Toolmaker Terminals
XS Power D1200
Viper 5706
I have used a HDD caddy which u put the hard drive in it and it makes it USB so you just plug into your pc and copy off you files you want to save. I did it for movies, music, pictures and whatever.
2007 Ford Ranger
(ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES)
K&N Performance Air Intake
Massive Audio D2400 Mono Amplifier
2 Custom Built 8" Subwoofers in Ported Enclosure
Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed)
4 - Pioneer TS-A6886R 6" X 8"
2 - SMD Heavy Duty Single ANL Fuse Blocks
2- Stinger SPP1200 Dry Cell Batteries
JL AUDIO Interconnects
2/0 Gauge Big 3
ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals
ILL Customz 1/0 to 4 Gauge Power / Ground Reducers
Factory Alternator
__________________________________________________________________________________________________________________________________
2002 Cheverlot Monte Carlo SS - (Deceased)
2 - Rockford Fosgate Power 1501BD
1 - Rockford Fosgate Power 851x
Rockford Fosgate Power 6 1/2 Components
Rockford Fosgate Power 3 way 6x9
2 - JL Audio W7 13.5" Subwoofers (Sealed)
Pioneer AVH-P4400BH In - Dash DVD Player
Pioneer AVIC - U250 - Add-on GPS Navigation System
Audio Control 6XS 4 Way Crossover / Line Driver
Ohio Generator 200 Amp Alternator
3 - Stinger SPP1200 Batteries
1 - Optima D34/78 Battery
What works for me while I was a comp tech...
I used Linux (Ubuntu) booted from the CD, did my file transfers from there.
See if that works? GL!
EDIT: Believe it or not, file transfers were LIGHTNING on that the Linux CD/DVD distro! lol
So you are saying that Linux will recognize the windows 8 partitions?
Sony MEX-N5000BT
JBL P660C x 2
Crescendo BC2000D
Crescendo S800/4
Toolmaker Terminals
XS Power D1200
Viper 5706
Thank you! I don't know why I didn't think about trying this before posting. I usually use Hirens disk which is all linux based anyway. I took the old drive out, hooked it up to another machine running Linux and it was right there. Thanks again. :)
Sony MEX-N5000BT
JBL P660C x 2
Crescendo BC2000D
Crescendo S800/4
Toolmaker Terminals
XS Power D1200
Viper 5706
might have bitlocker running on the old HDD.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
if it wont boot even on the lap top i am guessing it sustained a fall and has physic damage and a few bad blocks.
Can you access it at all from another machine?
if so run a surface scan and mark all the bad blocks and try to copy again.
May be getting a cyllic redundancy error, or as we used to call them "bad blocks"
edit:
nevermind, i see you got it. lol
The drive was out of a machine that was running windows 8. Windows 7 and older will not read the partitions created in 8. That was my issue. Linux saves the day!
Sony MEX-N5000BT
JBL P660C x 2
Crescendo BC2000D
Crescendo S800/4
Toolmaker Terminals
XS Power D1200
Viper 5706
