rsfm089 Posted May 7, 2014 Report Posted May 7, 2014 So I just ordered my wire and didn't think about fuses and ring terminals what fuses do I need to run. Will have aq3500 one day so two runs of 1/0 to the back of my car. Do I fuse both runs and what fuses do I use? Also where can I get ring terminals from for 1/0 gauge? Is there a cheap digital volt meter I can get for now until I can get the smd one. Might as well ask can anyone think of something I missed
truthsayer Posted May 7, 2014 Report Posted May 7, 2014 Go to Amazon and digital volt meters are cheap. As for the fusing the amp should you tell what is recommended. truthsayer
rsfm089 Posted May 7, 2014 Author Report Posted May 7, 2014 The aq3500 says it needs a 380amp fuse do I split that between the two runs or do I have to put a 380 fuse on each run. Where do I even find a 380 amp fuse.
SPL.Pantie.Soak Posted May 7, 2014 Report Posted May 7, 2014 Good question bro Kenwood KVT-614 (4) Marathon 155 AH batts 2/0 OFC SHCA Mechman 370 (2) Audioque 3500.1 (2) AA Mayhem 15s
jbeez Posted May 8, 2014 Report Posted May 8, 2014 looks like that amp has 2 0awg inputs, so if it were me I would put a 200amp fuse on each input leg. Good luck trying to find a 190amp ANL fuse, I think they are unicorns.
Popwarhomie Posted May 8, 2014 Report Posted May 8, 2014 What is the wiring rated at? 2010 Focus coupe- 8 12" wall. 157.5@46hz 2016 Focus ST - SQ build.
CleanSierra Posted May 8, 2014 Report Posted May 8, 2014 You fuse for the wire, that's what he was getting at. You don't fuse for the amp, you fuse to protect the wire and the vehicle. Fuse both runs of 1/0 gauge at whatever the rating of the wire is. If you're going to compete, you'll have to fuse down if it's an organization that takes fusing into account(MECA). Im not the one you want to try to troll. Just a fyi for you.
