12 cubes too big?
cheebs
12 cubes gross your good to go,should put you around 8-8.5 after displacement and a low tuned port.. 12 cubes net however is a shit ton of space. 2500rms per sub will be fine if you do not clip,that power will only come with no voltage drop and an uncommon enclosure that has little to no impedance rise. And no,you cant send 2500rms to a zv4 all day.maybe 30/45 mins before things get thermally out of hand,so make sure to give them time to cool after a full tilt session.
^that's what i said ; )
Sorry aj,i didnt see your post =). Hopefully he will take yhe professional advice.
all good, good advice is good advice.
and from reading his posts being a show trunk i don't think he's gonna go all HAM like we do! lol
it's been said enough now. I'm sure op gets it.
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
I ran 2 dc xl 15's with 12 cubes on 5k. But I had a 4th order
SOLD
2006 Ford Ranger Single Cab
2 DC XL 15's
2 Crescendo BC2k's
4th Order Blowthrough
CURRENT
2012 Dodge Charger R/T
2 Tantric HD 12's
Ampere 3800
2 XS XP 3000's
10 cubes net isn't a scary number for those subs. The original 2 was a little bit.
Aj, your advice wasn't bad now that I look back on it. Using common sense, setting gain properly, keeping an ear and nose on the subs should work. I just originally saw BIG box, overpowering and was like noooooo! It really shouldn't be bad at all and should be doable.
Bandwidth is up in the air though, I'm curious as to what kind of range it will have. I mean a bass reflex box by design, really IS supposed to have a bump at tuning and fall off above and below technically anyway. We just get greedy in car audio and want a box that's ported and had HUGE frequency range. The bass reflex isn't truly designed to do that, an acoustic suspension enclosure is meant for those results.
If one has 12 cubes to work with one get 2 18s not 2 15s, it is that simple, way more cone area, increased displacement, better bandwidth.
thanks i didnt think it was bad either.
i can say that the kid with the 18 i was referring To, his box is tuned at like 32-33hz and he has a major roll off anything above 40. he can kill the lies! and i mean slaughter them. but anything in the "spl".range isn't there.
i know there not really spl Subs to begin with. but if it was my subs my box (judging from his) id tune a lil higher to have a Lil more upper bass. say 35,337hz that should get Down in the high 20s in that big of a box. and hopefully get to or past the 45hz Area
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
no i got what yall saying.
  • Who's Online   0 Members, 0 Anonymous, 7966 Guests (See full list)
