can someone check out my final port calculations?
awesome thanks Joe, only thing i did differently was i didnt check the subwoofer facing up box so the cut sheet i got is different than the one above...so the program thinks im gonna mount the sub on the same plane as the port but im just gonna install it on the top..thanks for checking it out though, i just needed confirmation that i got the dimensions correct
The check in Torres actually doesn't make a difference as long as you don't use a double baffle, the cutsheet can be done in any way you like as long as the volume inside is the same, I just wanted you to see the port parts and the box specs are according to your plans.
@Joe x , you sure use alot of your time to help people on this forum from what i have seen .. it is much appreciated , and thanks to everyone else that has helped on here as well
No thank you, I'm glad to help.
  • Who's Online   0 Members, 0 Anonymous, 815 Guests (See full list)
