Swordlordboy1234 Posted May 14, 2014 Report Posted May 14, 2014 Sa10zv4 like a SA 10 motor with zv4 10 softies? Sounds like a big waste of zv4 softies. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
itry802 Posted May 14, 2014 Author Report Posted May 14, 2014 Here's a link to the sundown website, apparently they're still a protype woofer but they produce 1750 rms and are massive. IF i'm not mistaken they're sundowns top dawg: http://www.sundownaudio.com/index.php/products/subwoofers/item/z-v-4-series.html
FocusOn20s Posted May 14, 2014 Report Posted May 14, 2014 Sa10zv4 like a SA 10 motor with zv4 10 softies? Sounds like a big waste of zv4 softies. nah SA = Sundown Audio 10" Zv4
youngbass98 Posted May 14, 2014 Report Posted May 14, 2014 They aren't in prototype stage if I remember correctly they are out of stock currently and btw nightshade v3 is their top dog 06 monte carlo 2 12 rockford p3s soundstream rubicon 2500 crescendo audio mezzo 6.5 ct sounds 125.4 execution audio and shca wiring 2 xs d3400 on stock alt
itry802 Posted May 14, 2014 Author Report Posted May 14, 2014 yea I saw the nightshade being the highest wattage. I found the zv4's for sale on the net in different places. Just wanted to clarify that the two zv4's and the saz-2500D v.2 wired in parralell would turn the two ohm woofers to 1 ohm, and they would share the 2500 watts giving them 1750 rms a peice. But damn they are some sexy woofers!!
CleanSierra Posted May 15, 2014 Report Posted May 15, 2014 Don't run that amp at half ohm of you don't need to. Spend the extra money on the 3500 and get subs that are D1 coils, that way you can have the final load of 1 ohm at the amp. 2 Zv4 10s on that power in a SuperCrew should sound totally awesome in a well built enclosure. If and when you get this built, PLEASE post pictures! Im not the one you want to try to troll. Just a fyi for you.
itry802 Posted May 15, 2014 Author Report Posted May 15, 2014 I meant the 3500v.2 anyway* sorry! and if they're d1 coils, meaning they're 1 ohm woofers, i'd have to wire them in parraell to get them into a 1 channel amp. wouldn't that put them at a half an ohm load?
CleanSierra Posted May 15, 2014 Report Posted May 15, 2014 No, that's incorrect. Your options are 4 ohm or 1 ohm on a mono amp. Here is your diagram: It's not mathematically possible to wire two D1, subs together on a mono amp to each a half ohm final load at the amp. Im not the one you want to try to troll. Just a fyi for you.
itry802 Posted May 15, 2014 Author Report Posted May 15, 2014 I'll be going with option 1 for the 1 ohm load. with the v4-d1's wired up to that saz-3500 I'll start a new thread when I buy the subs and amp for my truck in a few weeks!
