SOLVED - Auto Problem - Help WTF - 1999 Denali
1999 Denali
5.7 Vortec
Been having strange issues lately. Started about 3-4 days ago.
First, for no reason one morning the truck didnt start. It turned over and would run for about 1-2 seconds then die. Fuel pump was replaced about 1-2 months ago and I could hear the pump clearly when it had this recent issue. Later in the day it started fine, no issues, drives fine and havent had a problem since then (I'm thinking maybe Crank Position Sensor on this one).
Second, my passenger side headlight went out. Just out of the blue and I think my high beam on that side is very dim. I'll just replace this
Third, and here is where it gets strange. I turned my right turn signal on and it flashes really fast, then slow, then fast. My first thought is oh this is just because of the light that is out. But my horn doesn't work. When I press the horn, the right turn signal flashes!! I turn the truck off, and the horn works. I start the ruck again and the horn makes the right turn signal blink.
Now individually I would think these are all isolated issues that need to be addressed, but prior to this I have had no issues with the electrical stuff in this truck. The stereo is still bone stock, stock battery, stock alt, no amps or aftermarket accessories. Is it just me or are these problems somehow related ? And how do I fix the third one ?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
no one ?
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
First thing id do is pull the panel under the steering column and start checking for modifications to the wiring amd then do the same thing with the under hood fuse panel and the fuse panel on the drivers side my guess is something waa installed aftermarket and then put back to good enough standards to sell
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
mom had this problem in her 2000 chevy.. ended up being the computer.
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
Solved - I didn't even think that i had recently had the front fender replaced. They stripped out the fender ground bolt so the ground for the harness on that side was barely touching, connecting sometimes and sometimes not. Took it back in and they "fixed" it. I could have fixed it but there were a couple of other things they missed so I wanted them to do it.
Thanks for the input guys.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
