94 Ford Beast-350 OBS CCLB - Motor is done, need to sell, questions-please help
Another thing to keep in mind here is that in that bath, you've probably removed any paint or protect-ant for the metal parts of the injectors. What's that mean? Well they could rust. They are in the elements even though protected by the hood. So I'm going to go ahead and make them look new by giving them a little paint job.
10397205_680147208761079_849687122418948
1524172_680147218761078_3092175148087487
1979085_680147248761075_8756644847633270
They got 3 coats of primer.
10952951_680147258761074_221333563725514
10955763_680147282094405_841343604997911
and three coats of enamel.
10960301_680147372094396_318356154343446
Marvelous!!
10974707_680147392094394_573308090577162
Add new parts, and she's ready to roll!!
10680064_680147405427726_637459197738171
10974697_680147432094390_660322414573839
Now back to the grueling work!!
First I had to remove the bolts and the PCV Valve.
10620450_680147442094389_664944018217033
I'm going to get a new one to replace it.
10498394_680147475427719_703241050362279
Also removed the internal shield that goes under the valve.
10974305_680147502094383_629410596940905
YUCK! Recall how dirty this one was, it was the first one I showed going in for the bath. This was after a week in the tub, and a little wire brush work. Not much at all. Except I should've removed that shield before I put it in the bath. Oh well.
10924685_680147535427713_306413196017334
CLEAN AS A WHISTLE!!
10842029_680147548761045_371392616570753
Time for the outside. Recall I used the wire wheel on the outside of the other one. This one I decided to take a different approach.
Paint remover!
1941512_680147565427710_6381583107371763
100x's easier. I did hit it with a wheel anyway, to get the stubborn stuff off. But you can see the difference between the two. Worked much harder on the one on the left.
10958967_680147602094373_142648206599419
Now let's clean up the fuel rail.
1978313_680147608761039_6167557603641297
Got the fuel regulator off.
10952142_680147628761037_540019135627218
Then I cleaned it up a bit in the parts washer.
Now comes the fun part!! Let's prep for paint!!
10338423_680147652094368_276354218110036
Primer 3 coats.
10861076_680147662094367_323410428811658
10847575_680147685427698_819785264765754
1799080_680147708761029_1806744645813001
Valve covers.
10974242_680147735427693_504906717887274
10945847_680147745427692_378077999481491
10983554_680147762094357_200701700624962
10974316_680147782094355_596038052479567
1412323_680147798761020_5271398456745724
10960204_680147815427685_212701955046864
1397101_680147828761017_8583983822888633
10257175_680147855427681_309252120761675
You all know I'm not going to leave it primer grey!! HELL NO!! How bout some color!!??
Old Ford Blue folks!!
10960339_680148092094324_648430534024786
Now that's purrrrrdy!!!
10887596_680148105427656_444022099265305
10887596_680148118760988_809285439674609
Wait what? Do it again? OK!!
10974526_680148148760985_196687056719448
Let's let that dry. We have more to cover.
NEW TIMING COVER!!! Yes it's a little different, but they thought of that.
Looks close to the same though huh!! Obviously old on the left new on the right. See the difference?
10974557_680148165427650_466833366460251
How about now?
10896400_680148185427648_134141140777539
Yes this little port on the side. But, like i said they thought of that. They gave me a little block off plate and some hardware for it, and even a gasket.
10957716_680148228760977_905138487544674
10955725_680148215427645_620565974724062
Taped off and ready for primer.
10498484_680148242094309_605738075539629
10920094_680148275427639_267827940991299
Out with the old water pump, in with the new!! This was one of the main issues with the leaking up front. This and the gasket, and the timing cover. All bad. That's why they're all getting replaced.
10887642_680148298760970_694764207273411
1518748_680148315427635_6997428633705268
10960365_680148338760966_234755586431265
Taped up ready for primer.
10848824_680148352094298_325858648952200
10920094_680148365427630_106771795261048
1540447_680148375427629_6391452287954329
Painted the fuel rail blue.
1492246_680148405427626_8360057467134602
And primed the timing cover and water pump.
10866233_680148422094291_155807874221806
And put some color on the intake!
10960351_680148438760956_140977100223278
10855056_680148465427620_115646094519936
Same as I used on the injectors.
10953925_680148475427619_126434450091731
Timing cover black.
10959919_680148488760951_586480178094654
10984508_680148512094282_518643471893708
This was that piece I didn't know what it was off the end of the intake. It's black now.
10915085_680148525427614_643024494801942
Good to see you're working on it, instead of someone else! For my 302 I just soaked my rockers and pushrods in diesel. Didn't go that far out with a partswasher. Sure ate the oil off them though lol. Would be nice if you could run the 9333PT1 headgaskets. Best ones you can get, IMO that aren't MLS. But if everything's setup right, i'd throw the MLS Cometics on, you can reuse them. Dunno if you looked into them options yet though.
Also, for the lower intake. I'd take your intake gaskets, put black RTV sealant on both sides of the water jackets, Then do the front and rear valley seal with RTV Sealant. Don't use the cork gasket or rubber gasket shit they give you, it will leak. I've done it this way plenty of times and no leaks. Throw your intake on and let it squash it down then let it seal for a few hours before starting ( if you do get it all done )
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
Water pump is blue.
10865896_680148535427613_676889181664456
10945393_680148558760944_897823160710789
This is the external balancing weight for the crank shaft. Needed cleaning bad!!
10974429_680148575427609_330671748474857
Nope, that's not new folks, same one. She's just clean!
10842029_680148605427606_799082925302201
10982768_680148642094269_888444847304479
She's ALSO NAKED!! COVER YOUR EYES!!!
10984587_680148648760935_183071183274532
10818495_680148665427600_119265799357906
While that dries, let's turn our attention to something else.
Cylinder heads. They were a little rusty. So I addressed them a bit. This one was tough. I was tired, and I ran out of the wheels I needed for this to get in all those little nooks and crannies!
10857100_680148715427595_374918031333321
10847346_680148725427594_560963687703023
10943759_680148745427592_453048302441829
10873384_680148772094256_410744116778325
After some wire wheel love.
10959960_680148788760921_526508342171567
The areas where the valves seat were pretty grimy so I thought I'd clean those up too. This is the driver side head. You can see the new valves, the ones that aren't marked with a number.
10914850_680148795427587_727266006312346
10317793_680148808760919_271788460478014
And done! God I love a wire wheel and an air grinder! Those little wire are like effing darts when they hit your stomach, but damn they make the job easier.
10974630_680148832094250_558802702530812
10960433_680148842094249_781813936533457
I didn't take a picture, but I did the other one that way as well.
It was time to come in, this was Sunday night, and this is about the end of what I've gotten so far.
10982397_680148862094247_783613855165021
10959959_680148878760912_641034587309311
10841782_680148892094244_753480691320069
So, some of the parts are painted. Still have the heads to tape off and paint, and then i want to remove the exhaust headers and paint those, plus some other stuff. The block needs some serious cleaning and attention, so that's the next big part of this. Once that's done, I can throw some paint on it as well. I'm hoping that with all this extra work, someone will appreciate it when the for sale sign goes up.
Katt, thanks. To be quite honest, this was a huge jump for me. I'm not a mechanic, but I know enough to be dangerous. I just knew I didn't want to pay someone to do it because I needed the budget to be able to replace the parts that needed replacing. So I said the hell with it and jumped in with both feet.
As far as the gaskets go, I have no clue what's a good brand or not. I honestly bought a gasket kit when I started this from RockAuto.com (EngineTech with FireSeal Technologies) :unknw: , and that's what I'm probably going to stick with. Like I said before, if I were going to keep it for sure, I'd have done all kinds of different things to it. I'd have changed the cam, the rockers, rods, and all kinds of stuff and made it a bunch more horsepower. But I honestly didn't want to put that kind of money into it when I'm going to sell it.
So that's all I have for now. It's supposed to rain this weekend so I may be halted for that. But we'll see, maybe I can get some stuff done in the shop and keep working. I'll post more when I have more to post. Thanks for tuning in.
  • Who's Online   1 Member, 0 Anonymous, 1177 Guests (See full list)
