this is prolly a stupid question but its the only thing holding me back from ordering wire. do i need a 4 channel rcas for a 4 channel amp. or do i just need 2 rcas like a subs amp.
equipment
http://www.rockfordfosgate.com/products/pr...S&p_status=
http://www.woofersetc.com/index.cfm?fuseac...Product_ID=1078
http://www.woofersetc.com/index.cfm?fuseac...Product_ID=6183
rcas
http://www.knukonceptz.com/productDetail.cfm?prodID=KRY4.6M
or
http://www.knukonceptz.com/productDetail.cfm?prodID=KRY2.1M
equipment
rcas
or
with this amp it can go four channel out with only two rca's in. you would need the other rca cables hooked into the other channels if you wanted front and rear fade capabilities and a little more stereo seperation. so its just on what you are planning to do. hope this helps
Edited by benz280se
what he said ... you need to send all four channels from the deck to the amp to get proper fade and balance control out of your deck...
2007 Toyota FJ Cruiser Voo Doo Blue
my upgrades and "build" thread.
My Kulicki Box Build
-Alpine 9887 head unit, KTX-100EQ imprint-( sound quality for dummies! ). - MB Quartz 3.5" in back pillars
-Sundown Audio SAX100.4 - JL Audio 3 way 6.5" component set XR653-CSi ( doors and dash )
-JL Audio 2 way Component set XR650CSi
- Alpine MRD - M1005 - Alpine Type - R 12" subs -- 2 - 12" s in a Pete kulicki designed box.
-Alpine High speed Ipod cable, and KCA-SC100 with Sirius sat. radio
-All wiring is Stinger 12 gauge and HPM Level 3 RCAs, KnuKonceptz Kolossus Power and ground and Big done in 1/0,
-270 sq. ft. of Damplifier Pro, 36 sq. ft. of Overkill Pro, 6 full sheets of Luxury Liner, and a gallon of spectrum-
-2 Powermaster D680 Powercells in back
FINALLY !!! I GOT IT METERED ON THE TERMLAB !!! I did a 140.2 at 42 hertz.
Shoehorn, BFH, forklift,duct tape and some zip ties
use either a four ch rca or two two ch rca both will work
1 meeter is 3 feet so you would need a 6 meeter or 5.5 meeter
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
12-14ga. mainly depends on how much power youre puting thru the wire, im running 4 speakers per ch. so im useing 12ga myself to be on the safe side
  • Who's Online   0 Members, 0 Anonymous, 991 Guests (See full list)
