When setting gain ?
Skax
Ok just got a few questions about setting gains with PAC lc1 I've been told to have it turned up half way and some say all the way during tuning the amps just would like to know also
When tuning should sub level on headunit be at 0 or turned to max when tuning because if I'm not mistaken if tuned at 0 then adjusted after setting gain it defeats the purpose and clips right ?
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Set the head unit 1st to the point where it distorts. So in your case set the sub level to max (though I like it 2 steps down). This is done to make sure you have the max unclipped signal from the head unit. Then play around with the gain starting all the way anti-clockwise going clockwise. Secret is just to avoid distortion and clipping. An oscilloscope would is the best way to set it though.
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
5.5 cubic feet box with 10 inch port @ 38hz
I live to hear the Bass drop!!!
Yes, have sub level maxed and have your knob all the way up when you tune your amps gain.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Your using the Pac1 and the RF bass knob? Rf, from another thread.
Ok another thing is I used -7.5db before I started listening to decaf and I was told to tune with -5db got decaf and and it seems alotttt less loud I mainly listened to rap/dubstep on -7.5db would I be fine using -7.5 with decaf tracks ?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Double post ...
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
using only PAC lc1 tuning with a dd1
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Also could the volume offset have played a difference in this ? I had it at -8 and turned it to -2 since it still stays unclipped at -2 but the ct
125.4 was to much for my current door speakers lol
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
keep lc1 all the way up while tuning gains. no idea why you would want to have less than max rca voltage going to the amp when tuning it to get the most power with the least amount of gain.
yea thanks bro I was thinking the exact same thing when I was told to leave it half way . What about the volume offset ?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
  • Who's Online   0 Members, 0 Anonymous, 764 Guests (See full list)
