07corolla Posted May 20, 2014 Report Posted May 20, 2014 The amp turns on and about a minute after that the clipping light goes on and stays on, it acts like its in protect but the protect light on the amp doesn't go on. Theres no output from the amp, voltage never went below 12v, checked all grounds, remote voltage was reading 10v and I hooked it up to the battery and still had the issue. Any help is appreciated 2007 Toyota Corolla Sub: DD M3c DD 9515h D4 wired to 2ohm Mids: DD A2 (2) DD VO 6.5 (4) Power: Js 180a alt XS D1200 XS XP3000 XS XP975 XS 1/0 OFC (Big 3) XS 1/0 OFC (2 runs pos/neg) Sky High machined set screw battery posts (all batts) Score: Never metered
07corolla Posted May 20, 2014 Author Report Posted May 20, 2014 DD M2a 2007 Toyota Corolla Sub: DD M3c DD 9515h D4 wired to 2ohm Mids: DD A2 (2) DD VO 6.5 (4) Power: Js 180a alt XS D1200 XS XP3000 XS XP975 XS 1/0 OFC (Big 3) XS 1/0 OFC (2 runs pos/neg) Sky High machined set screw battery posts (all batts) Score: Never metered
07corolla Posted May 20, 2014 Author Report Posted May 20, 2014 anyone have an idea? 2007 Toyota Corolla Sub: DD M3c DD 9515h D4 wired to 2ohm Mids: DD A2 (2) DD VO 6.5 (4) Power: Js 180a alt XS D1200 XS XP3000 XS XP975 XS 1/0 OFC (Big 3) XS 1/0 OFC (2 runs pos/neg) Sky High machined set screw battery posts (all batts) Score: Never metered
SIDE SHOW Posted May 21, 2014 Report Posted May 21, 2014 does it go into protect when there is no rca's going into the amp? also try disconnect the speaker/sub wires from the amp and test again
07corolla Posted May 21, 2014 Author Report Posted May 21, 2014 does it go into protect when there is no rca's going into the amp? also try disconnect the speaker/sub wires from the amp and test again The protect light on the amp doesn't light up only the clipping light on the knob, and it does this without anything being plugged in. Would that mean its something internal? 2007 Toyota Corolla Sub: DD M3c DD 9515h D4 wired to 2ohm Mids: DD A2 (2) DD VO 6.5 (4) Power: Js 180a alt XS D1200 XS XP3000 XS XP975 XS 1/0 OFC (Big 3) XS 1/0 OFC (2 runs pos/neg) Sky High machined set screw battery posts (all batts) Score: Never metered
SIDE SHOW Posted May 21, 2014 Report Posted May 21, 2014 unplug the knob at the amp........ does the amp work fine apart from the little led light on the knob flashing?
SIDE SHOW Posted May 21, 2014 Report Posted May 21, 2014 and when you say "without anything else being plugging in" have you unhooked/disconnected everything from the output on the amp aswell
07corolla Posted May 21, 2014 Author Report Posted May 21, 2014 and when you say "without anything else being plugging in" have you unhooked/disconnected everything from the output on the amp aswellI've tried unplugging the knob still no output. And yes I have unplugged RCAs as well as the speaker wires, only wires plugged in are power ground and remote 2007 Toyota Corolla Sub: DD M3c DD 9515h D4 wired to 2ohm Mids: DD A2 (2) DD VO 6.5 (4) Power: Js 180a alt XS D1200 XS XP3000 XS XP975 XS 1/0 OFC (Big 3) XS 1/0 OFC (2 runs pos/neg) Sky High machined set screw battery posts (all batts) Score: Never metered
