many questions
afrakes
I've got a few questions all pertaining to a built I'm helping a buddy with. We are looking around the 5k power range over 2 15's ported or 2 12's in a 4th order. The vehicle is a 2009 BMW 335I sedan;
1. He is set on a trunk build as he needs his back seats, problem is there is a firewall between the back seats and the trunk. No ski hole, no nothing. If we don't port through the rear deck, will there be any bass in the cabin, or just all audible rattles?
2. If we do a 4th order, how hard is it to design a decent enclosure? I have built many ported/sealed boxes, but never tried my hands at a band pass box.
3. If designing a box myself will be too difficult, what's the going rate for a full design including cut sheets?
4. I have never done an external port (if we go through the rear deck). How hard is it to do this and get the rear deck cut out lined up with the port opening? Any tips/tricks?
5. If we port through the rear deck but go with a basic ported design, would subs up or subs back be best?
I'm sure I'm forgetting a couple questions, so more may be on the way, but as always, I appreciate any and all feedback.
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
1) Yes there will be bass in the cabin. I was running 2 SA-12's in the back of my Cadillac Seville and it had a similar metal wall behind the seat. Still got plenty loud.
2) Most 4th orders on here are 2:1 or 3:1. This means that whatever your sealed total is, you need 2-3 times that for the ported area. This can make for some very large boxes when you are considering 2 15" subs. I don't know how big the trunk is but that might not fit.
3) Depends on who you go through. Many people on this site will help with design just for the love of the game. If you have the specs, you should be able to figure out the cut sheet.
2004 Pontiac Vibe Build
Sony MEX-N5000BT
JBL P660C x 2
Sundown Audio Zv4 18
Crescendo BC2000D
Crescendo S800/4
Execution Audio 0 AWG Wire
Sky High Car Audio RCA's
Toolmaker Terminals
XS Power D1200
DC Power 240HP Alternator
Viper 5706
Ok great. If we do a 4th, it would be a pair of 12s. We've got about 7.5 cubes to work with if I do a double baffle all the way around. That's before.displacements. And the reason I ask about how much I should pay for a design is I need this to be quality the first time. I don't have the time or money to be building a bunch of boxes, so I'd rather pay for a high quality design from somebody who has been there, done that. And get it right the first time.
Subs/Amps: TBD
Was thinking around 2.25 sealed and around 5 cubes ported (or a hair under) if we do a 4th, of course depending on the woofer selection he makes.
Subs/Amps: TBD
Double thickness walls anywhere but the baffle are just a waste of material and add needless weight IMHO. If you want more strength add more/better bracing.
Builds:
imo nothing sounds like a 4th. its allot harder but worth it! 2 12s in a forth ported up threw the deck will be devastating! the 15s might be just as loud and will be much easier to build.
i went threw the same issue a few weeks ago.
really wanted 2 15s mostly because i never owned 2 at a time. then i really wanted 2 12s in a forth... then 4 8s in a forth.
i finally made up my mind and went with one really really... really good 15. mostly to save a Lil space. all the amps batteries.. wires... deadner... takes up allot of room. if you take up your ewhole trunk with a box you need to plan for amps (NOT MOUNTED TO THE BOX!) and enough bats to handle that 5k. so your own planning first.
still wish i went with the 4 8s
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
Lol thanks for the replies. Yeah my buddy was really jet set on 15's, we may go that route. And electrical is a whole other set of restrictions with questions coming later on that. (in the right section, of course )
new question, if we go 15s in a standard ported box, not ported through the rear deck, would it be beneficial to put subs up port back suv style, but have the woofers as close to the back seats as possible so they are basically firing through the rear deck?
Subs/Amps: TBD
If you do subs up prepare for a lot of rattle. Sound deadener will be your friend. Also if you have speakers in your back deck you may damage them if the subs are directly under them.
no speakers in rear deck. And the reason I ask about placement of subs is the rear deck is deep enough that of the subs are all the way towards the back seats the entire cone area would be resting underneath the deck and wouldn't be pushing directly on the lid.
Subs/Amps: TBD
  • Who's Online   0 Members, 0 Anonymous, 2843 Guests (See full list)
