jarball25 Posted May 30, 2014 Author Report Posted May 30, 2014 http://www.stevemeadedesigns.com/board/topic/159860-roadmaster-wagon-build-dc-level-6-nsb170s-kicker-warhorse-vid-pg-3/page-3?hl=audiopipe buddy ran 2 strapped on one 18 beasting
n8ball2013 Posted May 30, 2014 Report Posted May 30, 2014 Those mojos are one of the most inefficient amps on the planet thats why they arent made anymore and are discontinued. Simply put your electrical is no where near enough for those amps. Theyd pull 650 amps of current or so per. Your alt and those batteries arent enough. Did you run it below one ohm? Yoyre going ro see 900 to 1000 watts of current draw if not more. They have a very low tolerance for issues. Low load low voltage and they pop. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
420c Posted May 30, 2014 Report Posted May 30, 2014 U should give these a try if your going budget amps. I believe the 8000 is only $850 www.stevemeadedesigns.com/board/topic/170576-my-test-taramps-hd3000/
jarball25 Posted May 30, 2014 Author Report Posted May 30, 2014 Those mojos are one of the most inefficient amps on the planet thats why they arent made anymore and are discontinued. Simply put your electrical is no where near enough for those amps. Theyd pull 650 amps of current or so per. Your alt and those batteries arent enough. Did you run it below one ohm? Yoyre going ro see 900 to 1000 watts of current draw if not more. They have a very low tolerance for issues. Low load low voltage and they pop. voltage boost modual i have ran them as high as 16.7v. your right about those amps they trash in my eyes. never ran below 1 ohm though. i agree 100% with what you said.
jarball25 Posted May 30, 2014 Author Report Posted May 30, 2014 U should give these a try if your going budget amps. I believe the 8000 is only $850 www.stevemeadedesigns.com/board/topic/170576-my-test-taramps-hd3000/ they seem nice but the audio pipes are already bought
jarball25 Posted June 30, 2014 Author Report Posted June 30, 2014 idk how you feel about audiopipe amps but 4 amps less than $200 each. i believe in audiopipe mini's
g2shuck Posted July 1, 2014 Report Posted July 1, 2014 Almost got sick when I seen aa on ap 2000 Toyota Camry With Sealed Off Trunk Sky High OFC Wiring DC Power 270 XP Alt AQ 2200 Sub Amp Two DC Level 4 m2 12s 80 Mil Murdetmat Gathering Parts For Wall Build. Team DC Audio 2014 Member
