Can someone explain this to me...?
Looks like the wire broke after the terminal. Whatever you did is holding the wire in the terminal but tearing off after it, i would replace that wire
yeah, but what i found weird was the fact that it wasn't only this wire, it was 2 of my grounds my main+ and my amp+
Sounds like the way you soldered it. Ive never seen that happen before. Crimping may solve your problem.
you have that hooked to the battery there in that pic? where does it go from there?
that was going from xs to my amp
2 Soundqubed SQ1-2200D
1 Soundqubed Q4-120
4 American Bass VFL 65MR
2 American Bass HD 15's
2 American Bass MX-250T
2 American Bass MX-252T
4 XS Power XP950
Tons of Sky High Car Audio Cable
"Do a proper install, something your happy with, Fuck everyone else......
improve in time, where you can..... its not rocket science..."
yeah, crimping all my wires tomorrow as soon as the crimper gets in
1 Soundqubed Q4-120
4 XS Power XP950
You may want to use die-electric grease on wires before inserting into fitting. Is you Cad wire CCA? If you soldered did you use the wrong solder? Use Marine grade heat shrink it has a waterproof adhesive built into it also to make it waterproof. Normal heat shrink is not marine grade
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
If it is cca it is quite easy to burn the strands if you get to close with a propane torch
06 monte carlo
2 12 rockford p3s
soundstream rubicon 2500
crescendo audio mezzo 6.5
ct sounds 125.4
execution audio and shca wiring
2 xs d3400 on stock alt
yeah its cca, I'm thinking it was the soldering, not sure if ill want to use heat shrink again, can't/won't really tell if my wiring is going bad (future references)
so for now i think ill stick with crimping
1 Soundqubed Q4-120
4 XS Power XP950
  • Who's Online   0 Members, 0 Anonymous, 26759 Guests (See full list)
