Separate Run for Ground
I have seen more than a few people here running a separate run of 0 ga (or more than one) from the front to rear instead of just grounding to chassis. I was only able to find one person who attempted quantifying this with actual data. I get the reasoning behind it - the copper has less resistance than the steel frame. But does anyone have any hard numbers of before and after doing this (db gains or voltage drop improvements would be stellar)? Are there other reasons?
I believe Tony Damore or CE auto electric supply did a video of it awhile back. Can't remember the results but it directly addresses this
edit:http://youtu.be/_Bpdh2BD-qI
Dorm room setup:
SQ SDC2.5 12" @ 8 ohms
Klipsch 300 watt home theater sub amp
Marantz 1030 amplifier
Future car build:
Audio Technix 1200.1d
Fi SSD 12 w/ cooling and flatwind coil
6th order dual reflex enclosure
Tony + Tony = Win.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
A good ground to frame is more than good enough for a ground. Don't waste money on running a negative to the front of the vehicle IMO
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
When I installed my mono amp, I ended up using the spot and bolt that originally secured one of the cargo hooks in my hatch (that I'm assuming you could use ratchet straps or rope to hold something down with, fairly beefy.) I removed the carbo hook, sanded down the bracket, and used the original bolt to secure the terminal on the ground wire.
Just out of curiosity, I took my DMM and checked resistance from the negative terminal of my amp to the seat mounting bolt on the opposite end of the hatch (as far from the ground point as possible.) I can't recall what I measured, but the resistance was extremely minimal, so I concluded (apparently correctly) that I was firmly grounded to the unibody and another ground run back to the battery wasn't needed.
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
  • Who's Online   0 Members, 0 Anonymous, 16732 Guests (See full list)
