Junior Pro Posted December 6, 2014 Author Report Posted December 6, 2014 Thanks man, I have done aome work on the car over the last month not much work, but every little thing get checked off the to so list slowly. I'll post up some pictures over the weekend at some point.
Junior Pro Posted December 11, 2014 Author Report Posted December 11, 2014 SO I got some work done over the weekend, got my power windows installed and working. Found the perfect place for the switches for the power windows. Started thinking about a head unit and found a JVC KX-NW7000 for $120 shipped, so I picked up. It sure was packed nice and tight in the box. I didn't know it came with the Bluetooth adaptor so it was a nice surprise when I saw it, just too bad it doesn't work. I was originally going to move my heater control to the bottom of the centre console but decided to keep them in the factory location. So instead I modified the console for the JVC deck, I did loose my cup holders but who need that anyways. lol Plus this way it leave me the dash for a future upgrade, thinking of a iPad mini in the dash. Will see what happens in the near future. I sanded and drilled hole all the way around so the kitty kat hair had something nice to grab. Then it was time for some filler. I still need to give it one more coat of filler for the small pin holes and imperfection but wanted to see what it looked like. Turned out pretty nice and happy with all the custom work I'm doing as its my first time doing any thing like this. I also order some 5M RGB led light, 5M RGB wire, 10 X RGB male and female connectors, 4 X push button black aluminum switch, 2 X volt meter, 6 X 6 position terminal connectors, fuse and holders so I can try out the doors. and a new soldering iron as I went to use mine and it no longer worked.
RossGo Posted December 11, 2014 Report Posted December 11, 2014 What kind of iron did you get?I just got a new one for doing a ton of LEDs in a house, and it made it so much easier having a nice one, especially with a sponge basin Great job on the kitty hair. I should have done that on my ipad dash, but I didn't know at the time and used body filler for structure. No issues, but there easily could be in the future haha It's coming together nicely Yes I have a lot of stereo weight. I build for Smiles Per Gallon not Miles Per Gallon LOLZ My build - 1996 4Runner with 2 18s - 149+ in a sealed box (with radiators)
Junior Pro Posted December 11, 2014 Author Report Posted December 11, 2014 I had a Weller station and can't remember when the last time I used it. So I just got a Weller pencil iron, will do the job I need it to. Ya the kitty cat hair is great to use before the filler, I was going to glass the console and figured the kitty cat hair will be just as good. You just need to remember to drill some holes for it to grab, cause I don't think it would have held with out them. ( so I have been told) Dashes and console are pretty smooth and wasn't sure if just sanding would have been good so I went the extra step.
RossGo Posted December 11, 2014 Report Posted December 11, 2014 Looks like it paid off Yes I have a lot of stereo weight. I build for Smiles Per Gallon not Miles Per Gallon LOLZ My build - 1996 4Runner with 2 18s - 149+ in a sealed box (with radiators)
Junior Pro Posted December 11, 2014 Author Report Posted December 11, 2014 Ya turned out good I think, going to work on it some more tonight.
Borris The Blade Posted December 11, 2014 Report Posted December 11, 2014 Looks good man. Was gonna do the same in my accent when I had it. It's like rubbing your wiener up against a sheep.
Junior Pro Posted December 21, 2014 Author Report Posted December 21, 2014 SO I have 2 deck witch of the 2 would be a better deck? Pioneer Avic F700BT OR JVC KW-NX700
Junior Pro Posted December 27, 2014 Author Report Posted December 27, 2014 No help on deciding on what deck I should use?
islandpride684 Posted December 27, 2014 Report Posted December 27, 2014 No help on deciding on what deck I should use? JVC Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
