slaughter Posted May 29, 2014 Report Posted May 29, 2014 The speakers that are in my rear deck that I'm going to use for my LC6i have all the factory wires together in a plug for the speaker. So how will I be able to add a wire for the LOC into that? thanks SOLD 2006 Ford Ranger Single Cab2 DC XL 15's2 Crescendo BC2k's4th Order Blowthrough CURRENT 2012 Dodge Charger R/T 2 Tantric HD 12's Ampere 3800 2 XS XP 3000's
Pro7 Posted May 29, 2014 Report Posted May 29, 2014 You can use a quick splice on the wires going into the speaker. These little guys are what I have been using http://www.sonicelectronix.com/item_41169_Xscorpion-QS2218R.html I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before
P4killer_ Posted May 29, 2014 Report Posted May 29, 2014 Not to say that those scotch lock things dont work at all, but I personally hate them. They are cumbersome, kinda bulky when you need like 12 of them for a LOC. They can chew up the wire and really they only create a very small contact point. I used em. They were the right size etc. Within a month the xonnections loosened causing a little noise. I stripped and soldered after taking all those locks out which I spent so much time securing, so it took awhile. Not only did it take up less space and was neater, I havent had a problem since. Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
BoomZoom808 Posted May 29, 2014 Report Posted May 29, 2014 You can use a quick splice on the wires going into the speaker. These little guys are what I have been using http://www.sonicelectronix.com/item_41169_Xscorpion-QS2218R.html I used these for my Mag when I was using a LOC then using High Level inputs. If you don't like these you can also use the Posi products T-Tap. If I could do it all over again I would have gone straight to aftermarket Head unit unless you are doing a higher end processor like a 360.3. Loc's are meh 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
