Wiring LOC
The speakers that are in my rear deck that I'm going to use for my LC6i have all the factory wires together in a plug for the speaker. So how will I be able to add a wire for the LOC into that? thanks
SOLD
2006 Ford Ranger Single Cab
2 DC XL 15's
2 Crescendo BC2k's
4th Order Blowthrough
CURRENT
2012 Dodge Charger R/T
2 Tantric HD 12's
Ampere 3800
2 XS XP 3000's
You can use a quick splice on the wires going into the speaker.
These little guys are what I have been using
http://www.sonicelectronix.com/item_41169_Xscorpion-QS2218R.html
I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before
Not to say that those scotch lock things dont work at all, but I personally hate them.
They are cumbersome, kinda bulky when you need like 12 of them for a LOC. They can chew up the wire and really they only create a very small contact point.
I used em. They were the right size etc. Within a month the xonnections loosened causing a little noise.
I stripped and soldered after taking all those locks out which I spent so much time securing, so it took awhile. Not only did it take up less space and was neater,
I havent had a problem since.
Setup:
2010 Hyundai Elantra
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
DD M3b and 2 12" AQ HDC4s
I used these for my Mag when I was using a LOC then using High Level inputs. If you don't like these you can also use the Posi products T-Tap. If I could do it all over again I would have gone straight to aftermarket Head unit unless you are doing a higher end processor like a 360.3. Loc's are meh
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
  • Who's Online   0 Members, 0 Anonymous, 1116 Guests (See full list)
