Well im starting on the wall. It will be 38x38x34 3/4mdf so around 25cubes before port and sub displacement. It will be 4 DC lvl 4 15s so i need a port size.
http://s275.photobucket.com/albums/jj301/h...k=nav_tab_album
I hope you guys like and i will take comments lol
Edited by LoudBlazer
1997 2 Door Blazer
Bagged & Body Dropped
SBC/TH350
start off with the floor. look under the car and see where you can make mounting points. go get some 2x4s, 1/2" or 3/4" lag bolts, washers, and nuts (however long of bolts you need) and use the 2x4s, and bolt them to the floor. use 2x4s to get a level surface, and then put a piece of 3/4" mdf and glue and screw it to the bolted down 2x4s. you now have a flat surface to work with, and start building the box and slide it in, or however you like.
i put some liquid nails under the 2x4s, so the 2x4s arent directly touching the metal body, might help with small annoying rattles/squeaks that might occur after a while. just an idea.
heres some pics of the wall we built in my 97 explorer (not in anymore)
see the bolts?
leveling up the floor
I want to do a wall. Not sure where to start. Anyone have a link or pics to a very good wall build? It will be in a 2000 4 door blazer
Check mine yo....If ya need a hand, I may be able to make it down for a weekend and we can make it happen :)
A half-wit gave you a piece of his mind, and you held on to it.
anythings possible with the right build =] we accept visa and mastercard =]
Well i plan on running 4 DC lvl4 15s . No plans to take out the carpet or headliner lol so we would have to work around it. Where in florida are you from pimpedout97x? I like that idea 00sdime00! Might wait til after SBN so i can see some ideas at the show. But this is def my next box :) i want a sexy blazer wit ha nuts install
1997 2 Door Blazer
SBC/TH350
Well...let me know Pete...I am down to help if I can make it :)
tampa
want to do a wall in a silverado :)
DC.jpgDC POWER
ah thats right your thewes boy?! He said he will prolly hitch a ride with you to SBN lol
1997 2 Door Blazer
SBC/TH350
