Amp starts to smoke and sizzle
slaughter
track 5, it worked fine after the shop and sounded great. Once I knew the amp was set up correctly I took the box out and made sure all the wiring was nice and tight ect..
Then I plugged in the amps power and ground like I've done numerous times so far and poof smoke.
SOLD
2006 Ford Ranger Single Cab
2 DC XL 15's
2 Crescendo BC2k's
4th Order Blowthrough
CURRENT
2012 Dodge Charger R/T
2 Tantric HD 12's
Ampere 3800
2 XS XP 3000's
Any time I unhook power to and from my amp I always always take out the fuse at the battery for the amp. Then when everything is hooked up I pop the fuse back in.
Bummer so does the amp work now or is it toast?
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
  • Who's Online   1 Member, 0 Anonymous, 759 Guests (See full list)
