Amp starts to smoke and sizzle
slaughter
Hello, so my system has been hooked up for a few days now, today I went to the shop and put it on the dd1 and o scope. Went back home and went over some of my wiring, some terminals were coming loose. Once I got all those done and better than before everything all good I go to hook up the amp, I go to plug in the power/ground and boom smoke and some sizzling. Any thoughts?? I checked wiring multiple times, it is correct and same as before..
SOLD
2006 Ford Ranger Single Cab
2 DC XL 15's
2 Crescendo BC2k's
4th Order Blowthrough
CURRENT
2012 Dodge Charger R/T
2 Tantric HD 12's
Ampere 3800
2 XS XP 3000's
boom smoke as in - "BOOM!" then smoke or do you mean to say that smoke just happened with no sound ?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Sounds like you should have disconnected your battery's ground before doing anything electrical kinda problem
06 monte carlo
2 12 rockford p3s
soundstream rubicon 2500
crescendo audio mezzo 6.5
ct sounds 125.4
execution audio and shca wiring
2 xs d3400 on stock alt
You didn't accidentally switch the power and ground did you? I'll admit it, I did it with my DC 2.0k the first time I hooked it up. Luckily it was fine. You also didn't have speaker wires connected to the amp and no speaker did you? Possible they touched. Sounds like a short somewhere.
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
subs are hooked up to the amp, no I didn't switch them , I thought I did at first then I checked over and over
SOLD
2 DC XL 15's
2 Crescendo BC2k's
CURRENT
2 Tantric HD 12's
Ampere 3800
2 XS XP 3000's
I have unplugged the amp and plugged it in numerous times and just this last time its done this
SOLD
2 DC XL 15's
2 Crescendo BC2k's
CURRENT
2 Tantric HD 12's
Ampere 3800
2 XS XP 3000's
Hmmmm
i recommend turning the gain up......
and the vol knob?
just me..
what??
SOLD
2 DC XL 15's
2 Crescendo BC2k's
CURRENT
2 Tantric HD 12's
Ampere 3800
2 XS XP 3000's
  • Who's Online   1 Member, 0 Anonymous, 759 Guests (See full list)
