Flamingsword360 Posted June 3, 2014 Report Posted June 3, 2014 Ok So I currently have a single 10" sub and I just got my box for my 12" its 1.50CF Tuned to 36hz I don't want to spend a ton of money on a sub arround $150 for a single 12". I have a Hifonics ZRX-1000.1D I know it won't do 1k rms. I was told it should do arround 700-800 RMS @ 1ohm.Someone suggested I get a soundqubed HDS-212 D2 and if I upgrade to a SQ-1200D Then get the HDS-312 D2. I also looked at a Audiopipe APCL1500.1 saw a video and it did arround 1450 on a amp dyno @1-ohm. This single 12" will be going in a EXT CAB Truck is there really a need for a amp that dose 1400rms for a daily driver? Also it has a 90 AMP ALT Its going bad and I can get a 130AMP alt for like $130 new.
khinds94 Posted June 4, 2014 Report Posted June 4, 2014 In all reality you should be designing your box based on your sub selection. However considering you already have a box I would look at anything in the ssa store such as sa-12 or gcon. 03 Sable LS AA mayhem 12" D2 Sundown ZV4 12" D1 Tantric HD 12" D2 Tantric SHD 12" D1 Sundown X12 V2 D2 2.5 cu net Sundown 2000d @ 1 ohm XS Power XP2000 Sky High Sound Deadener Sky High wire Stock alt
Flamingsword360 Posted June 4, 2014 Author Report Posted June 4, 2014 In all reality you should be designing your box based on your sub selection. However considering you already have a box I would look at anything in the ssa store such as sa-12 or gcon. Well The box was free and its the max size I can fit. Now if need be I can make like a baffle and change it to fit 1 10" sub. but its still going to be around 700-800 RMS.
Joshoe Posted June 4, 2014 Report Posted June 4, 2014 Ok So I currently have a single 10" sub and I just got my box for my 12" its 1.50CF Tuned to 36hz I don't want to spend a ton of money on a sub arround $150 for a single 12". I have a Hifonics ZRX-1000.1D I know it won't do 1k rms. I was told it should do arround 700-800 RMS @ 1ohm.Someone suggested I get a soundqubed HDS-212 D2 and if I upgrade to a SQ-1200D Then get the HDS-312 D2. I also looked at a Audiopipe APCL1500.1 saw a video and it did arround 1450 on a amp dyno @1-ohm. This single 12" will be going in a EXT CAB Truck is there really a need for a amp that dose 1400rms for a daily driver? Also it has a 90 AMP ALT Its going bad and I can get a 130AMP alt for like $130 new. Considering your boxb (if that IS your maximum space available) i'd stick with your one ten.. Is your box ported or sealed?
Joshoe Posted June 4, 2014 Report Posted June 4, 2014 Ok So I currently have a single 10" sub and I just got my box for my 12" its 1.50CF Tuned to 36hz I don't want to spend a ton of money on a sub arround $150 for a single 12". I have a Hifonics ZRX-1000.1D I know it won't do 1k rms. I was told it should do arround 700-800 RMS @ 1ohm.Someone suggested I get a soundqubed HDS-212 D2 and if I upgrade to a SQ-1200D Then get the HDS-312 D2. I also looked at a Audiopipe APCL1500.1 saw a video and it did arround 1450 on a amp dyno @1-ohm. This single 12" will be going in a EXT CAB Truck is there really a need for a amp that dose 1400rms for a daily driver? Also it has a 90 AMP ALT Its going bad and I can get a 130AMP alt for like $130 new. Considering your box (if that IS your maximum space available) i'd stick with your one ten.. Is your box ported or sealed? Its ported tuned to 36hz i would just re-baffle it to fit your 10.. But not sure if you want to go and build another box. Just make sure to take in the added depth to make sure the enclosure fits..
Flamingsword360 Posted June 4, 2014 Author Report Posted June 4, 2014 What 10" would you recommend? for say 750rms please under $150 maby soundqubed HDS210?
truthsayer Posted June 4, 2014 Report Posted June 4, 2014 http://www.ebay.com/itm/American-Bass-Cast-Frame-220Oz-2000W-Magnet-Subwoofer-Sub-2000-Watt-/321402468341?pt=Car_Subwoofers_Enclosures&hash=item4ad51477f5 truthsayer
Splatter Posted June 5, 2014 Report Posted June 5, 2014 You can get the same Rockford Fosgate 10" P3 sub that Steve is using in his Polaris for like $120 on Amazon or $115 on eBay and it's 500W RMS Here's the link to the one on Amazon; http://www.amazon.com/Rockford-Fosgate-P3D4-10-500-Watt-Subwoofer/dp/B004UFHXOC/ref=sr_1_1?ie=UTF8&qid=1402006724&sr=8-1&keywords=rockford+fosgate+p3+10%22
alaskanzx5 Posted June 6, 2014 Report Posted June 6, 2014 If its a prefab double check net volume, port area and tuning. Prefabs ate usually off from a small amount to a big amount t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
