1-15" Box Idea Rear Deck in 96 Cadillac
MNBEAST
[sharedmedia=garage:vehicles:2820]
4 cuft net 11sq in port per cuft. @32 hz
Most of my music is around 30hz so I dont know if I should go with more port area?
The sub will be in the rear deck and ported thrue the arm rest hole.
The Woofer will be a Precision Power PH-15 sound qubed HDS315!!!!
Powerd by a Precision Power PPI BK1800.1D. something cheep
BTW this is a budget build.
DC lv 4 18" 7cuft 31hz shaken the dash with .6krms LOL
I could shrink it to 3 but then Im having trouble keeping the tuning and port lenght acceptable.
I guess my question is will 11 sqin of port affect output? its not like this sub has a ton of xmax????
Try 3 cubic feet net with 12 sq inches of port per cube. You will be fine with 3 cubes net. 4 cubes would probably destroy that sub assuming the woofer has loose softparts. Btw maximum reccomended vol is 2.75. I dont see how you are having trouble getting a 3 cube net box to 30hz. It would probably be around 4ft gross.
Firstly running your sub with double its rms rating(assuming 1ohm load) in a box bigger than recommended will just cause problems. You will end up messing your sub. I'm sure if you take your time you can come up with a 3 cube box. You could also send your dimensions and maybe we could help you abit
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
5.5 cubic feet box with 10 inch port @ 38hz
I live to hear the Bass drop!!!
  • Who's Online   0 Members, 0 Anonymous, 3117 Guests (See full list)
