SlamminBeats Posted June 6, 2014 Report Posted June 6, 2014 with those max dims are you building box in trunk if not have you made sure those dims will let the box fit in the trunk when sliding in?
tayodell41 Posted June 6, 2014 Author Report Posted June 6, 2014 with those max dims are you building box in trunk if not have you made sure those dims will let the box fit in the trunk when sliding in? Yes. That size can be slid in and out.
SlamminBeats Posted June 6, 2014 Report Posted June 6, 2014 with those max dims are you building box in trunk if not have you made sure those dims will let the box fit in the trunk when sliding in? Yes. That size can be slid in and out. was just checking. Why not play around in torres? i would for you but im at work
tayodell41 Posted June 6, 2014 Author Report Posted June 6, 2014 with those max dims are you building box in trunk if not have you made sure those dims will let the box fit in the trunk when sliding in?Yes. That size can be slid in and out. was just checking. Why not play around in torres? i would for you but im at work I would but I don't have a computer.
Joe X Posted June 8, 2014 Report Posted June 8, 2014 You should not do sub up and the only option is doing something like this: This box style is hard to build properly, and despite some people asking about it, no one has attempted to build it to my knowledge, if you want some good advise go for 2 cool 12s and build for them, it will be much easier and smaller and you will get better results.
