2 runs of 0 awg from alt to front battery?
So i think i have bad connections which could be causing low voltage and need to check things out better but i was wondering if 2 runs of 0 gauge from alt to front battery would help with charging.
Heres my set up:
Singer 200+ alt
Optima blue top under hood
Kenetic HC600 under the hood also
2 Kenetic HC1800 in rear trunk
0 gauge from alt to BlueTop,
0 Gauge from HC600 to BlueTop
2 runs of 0 gauge to 2 HC1800s in rear trunk.
T400-4 x2
T400-2
T1500dbcp
HDS310s @ 1 ohm of T1500 on fult tilt and volts can drop to 13. Too low
Probably not, the one run can handle way more than the 200 amps you're alt will put out
Edit: assuming its high quality 1/0
Cool, thanks for the info.
  • Who's Online   0 Members, 0 Anonymous, 4525 Guests (See full list)
