Sub Cabinet Designs for PA/DJ use
I'm looking for plans for 2 different cabinets for PA/DJ type events. one using 2x 18" Sundown X series, and the other using 2x Skar 18" ZVX series. Both cabinets will be seeing their max recommended power, ~3k each. They are for 2 different venues if that matters, so they don't need be the same in any manner.
If you could help out I'd be happy to compensate you via Dogecoin, Bitcoin, Litecoin, or vaping supplies!
thanks in advance
It'll be rainy for me tomorrow so I'll be bored.
Shoot me a PM tomorrow so that I can get all the information you need without the clutter up in here.
Krakin's Home Dipole Project
Curious as to what audio amps you will be using.
Behringer iNuke NU6000DSP
http://www.behringer.com/EN/Products/NU6000DSP.aspx
Subs are D1s for nominal 4 ohm load per channel/cabinet.
I'll msg, not sure what all info you need I'll just tell you everything that might be relevant. Thank you sir!
I suck at designing cabs otherwise I would have a go, if you have room a large horn inclosure will be effecent as heck and they get low as well.
Also dont trust the meters on that amp. Ive seen lots of people simply blow them up lol they arent built the best by any means so just keep an eye on it
PSN: Rcp_soundz
Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at.
I'll stick a 300 amp fuse in a potato and sell it to you for $2k.
1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
