jmanjr82 Posted June 12, 2014 Report Posted June 12, 2014 The box is for a Nissan Skyline the max dimensions usable are: H-12 W-28 D-18 Looking for sub back port back tuned at 32-36ish hz sub specs: Enclosure SpecificationsSealed : 1 Ft^3 Ported : 1.5-2 Ft^3 @ 34 Hz Displacement : 0.14 Ft^3 Mounting Depth : 7.2" Mounting Cut-Out : 11-1/8" Magnet Diameter : 7.5" Outer Diameter : 12-5/8" T/S Parameters (D2/D4)Re : 2.1 Ohms Spl : 84.26 dB Qms : 4.861 Qes : 0.493 Qts : 0.448 Rms : 13.208 Kg/s Cms : 0.053 mm/N Nref : 0.161% Bl : 16.454 N/A VAS : 8.23 L Lp : 14.45 mH Cp : 812.89 uF RMS Power : 1000 Watts
Joe X Posted June 12, 2014 Report Posted June 12, 2014 Here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, port clearance 2 1/2", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Gerardo Herrera Jr. Posted July 17, 2016 Report Posted July 17, 2016 The box is for a Nissan Skyline the max dimensions usable are: H-12 W-28 D-18 Looking for sub back port back tuned at 32-36ish hz sub specs: Enclosure Specifications Sealed : 1 Ft^3 Ported : 1.5-2 Ft^3 @ 34 Hz Displacement : 0.14 Ft^3 Mounting Depth : 7.2" Mounting Cut-Out : 11-1/8" Magnet Diameter : 7.5" Outer Diameter : 12-5/8" T/S Parameters (D2/D4) Re : 2.1 Ohms Spl : 84.26 dB Qms : 4.861 Qes : 0.493 Qts : 0.448 Rms : 13.208 Kg/s Cms : 0.053 mm/N Nref : 0.161% Bl : 16.454 N/A VAS : 8.23 L Lp : 14.45 mH Cp : 812.89 uF RMS Power : 1000 Watts Here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, port clearance 2 1/2", figure is just an assembly guide: NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. Does this box fit my 05 chevy colorado if I remove one of the seats. its for the same sub?
Joe X Posted July 18, 2016 Report Posted July 18, 2016 The specs would work but the layout could be different, do you have a reg cab?
Gerardo Herrera Jr. Posted July 19, 2016 Report Posted July 19, 2016 Also which wood would you use to build the box Birch or MDF?
