Rookie needs help with burp box
Daboxxstl
I am wanting to compete in midwestspl with my car. It is a 1991 honda civic hatchback. I have a Digital designs 2515 d2 and an digital designs m1b. The power class I'm wanting to do is the 500 watt class and many people have been doing around a 145. What box would you guys recommend me building for this setup?
I would build about a 3 - 3.5 ft3 box and do an external aero port. Sub back and port toward passenger side. External port would be for ease of trying different tunings without affecting box net space. I would start in the high 30's and keep going until you find the cars peak. Trial and error.
I was thinking around that would be the right size but I wasn't 100% sure and I figured I would get some other people's input.
you need more power.
if i were burping a 2500 i would through at least 2k at it maybe more, assuming its clean power and be tuned in the mid 40s for starters. Before any box tuning id build it to be tuned in the 50s lol. That's me and i dont know much about burping only but i do know about DD subs and what they can take and what to expect from them when tuned at "x"
you may get louder then on a bigger box since this would be a low power application.
this changes things. Now if it were me id put that 15 in at least 5 cubes net
make as large of a box and port. try haveing 18-20 sq in per cube. 18 will yield some musicality, 20 is starting to get a little peakier but it also depends on car. things can change. but id start there. try getting 4.5-5 cubes net. and run at 1 ohm and you should be good
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
I also have been told to build around this size. Which will yield more spl the 3-3.5 cubes or the 4.5-5 cubes? I'm wanting to shut down my class.
  • Who's Online   0 Members, 0 Anonymous, 3159 Guests (See full list)
