Rookie needs help with burp box
Daboxxstl
make as large of a box and port. try haveing 18-20 sq in per cube. 18 will yield some musicality, 20 is starting to get a little peakier but it also depends on car. things can change. but id start there. try getting 4.5-5 cubes net. and run at 1 ohm and you should be good
I also have been told to build around this size. Which will yield more spl the 3-3.5 cubes or the 4.5-5 cubes? I'm wanting to shut down my class.
4.5-5 cubes in theory should make your box more efficient. and also a larger port will help.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Thanks I need all the help I can get in this. I have done a few builds before but not an spl build. I'm wanting to be as loud as possible on low power.
a lot of people have great luck with external aero ports. id try doing 2 6 inch aeros for that 15 and see how she likes it. persoinally i like slot ports and thats why i recommended arund 20 sq in per cube
BMW M340 xDrive
And then after I build the box and test it and get the numbers I'm wanting, should I glass th inside of it?
im not sure if glass helps or not. if you do glass it, it is just to seal it and make it smooth. if it were me iod double layer the walls of the box before i glassed
BMW M340 xDrive
I was probably going to do that too. At least a double baffle
  • Who's Online   0 Members, 0 Anonymous, 3159 Guests (See full list)
